Honeywell RTH230B When I took the face plate off, a small silver thing fell. I don't know where it came from. It is about 1 inch long. There is pentagonal shape on one end, 3-dimensional. The other end is flat and has 2 prongs on the side. Can someone help me figure this out. Without this piece, there is no display, it is blank. Thanks.
    Guru:
  • 588 Answers
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Jun 07, 2010
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
Heat not coming on. battery died.
Please go to the link and check graph "2.5 Installing the Batteries". Its really easy so it should be a piece of cake.https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf
Mar 30, 2014 | Honeywell RTH230B 5-2 Day Programmable...
Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
May 24, 2010 | Honeywell Electronic Programmable...
My Honeywell RTH230B temp control problems
Yes, some thermostats rely on batteries for power to run and maintain programming
Jul 02, 2009 | Honeywell Heating & Cooling
Iway 350c GPS battery
I don't know if this is the recommended way. Hold the unit facing you and look at the top of the unit. There is a seam about ¼” from the front. I simply used a small jewelers screwdriver and inserted it at the top of the unit about 1" from the side. I lifted the front section a little bit. It released one of six tabs that hold the face plate in place (two on top and two on each side). Repeat the same step on the other side then the sides. When you remove the face plate the silver on/off button will fall out, but don’t worry about that. Here is the tricky part. It has four star screws holding the back of the case to the electronics unit. I took a trip to the local Harbor Freight store and bought a star wrench set for $3.99. Remove the four screws and presto you can take the back casing right off. The batteries are at the bottom, but I can’t find any info on what type they are, so I don’t know what to replace them with, at least not yet.
Oct 12, 2008 | Lowrance iWAY 350C GPS Receiver
1998 beetle radio buttons
The face plate buttons actually activate small buttons on a printed circuit board behind the face plate. When I removed the radio and then the face plate many small pieces of plastic fell from behind the face plate. These small plastic pieces align the face plate button to the printed circuit board buttons. My Beeetle is almost 10 1/2 years old so I imagine the plastic is just becoming brittle with age. I could not set the radio to FM, so I removed the face plate button and now slide a toothpick in the slot to toggle between FM1 & FM2. Not he best solution, but probably the most inexpensive one. I also made my on tool to remove the radio from a diagram found at: http://www.alientech.net/nbinfo/stereo.html
Jul 02, 2008 | 1998 Volkswagen Beetle
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
