Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Tv is blinking on and off
Tv will blink on and off. we turn tv off and it will stop blinking for a short period of time before it starts right back up.
    Sergeant:
  • 261 Answers
I think you have a bad capacitor in the power supply circuit. You need to have a certified technician look at it though. Get someone who is familiar with mitsu's though. Have a great day. Jay
Posted on Jul 06, 2010
Flashing green power light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link.
Dec 07, 2013 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Dynex dx321221a12. light on front that blinks when you cut tv on blinks all the time and the tv want come on
It sounds that the IIC Bus rail has a short circuit. This is a skilled work to detect.
Feb 07, 2013 | Televison & Video
Will not turn on, red light blinks 4 times
In general when you have a blink of 4 times.
It indicates the Vertical deflection is stopped.
Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board)
Symptoms of the problem: TV has entered the standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
To guide you in the right direction do provide details about your TV .
Hope this helps .
Jan 23, 2010 | Sony Televison & Video
Our big screen sony tv stopped working yesterday. The power on light is blinking red intermittently and when you push it, it doesn't turn on-no sound or picture. It will stop blinking red periodically, but...
Please try disconnecting all the cables from the TV including the power cables then reconnect them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then service will be required.
Aug 27, 2009 | Sony Televison & Video
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV makes a spinning noise coming from the lower right side.
If there is a red light blinking that means that the projection light needs to be replaced.
Jul 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv shuts off by itself then flashes a code 8 blinks
Eight blinks means, "High voltage error". The probable cause location listed is "T8005 is faulty (D board). T8005 is the fly-back transformer (FBT). or you can replace the full d-board
You may purchase the D board complete for $185.10
or send in for repair here
if one of the crt is shorted it can also cause this problem.
Jan 30, 2008 | Sony KP-57HW40 57" Rear Projection...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
