Computer Bought My Book external harddrive it was working, now our computer doesn't recognise the harddrive comes up with 'Unknown device' 'Windows does not recognise'. When installing a message comes up saying "didn't pass windows test' Thanks Jen
First check all connection.Then format the operating system and reinstall it.
Posted on Apr 10, 2008
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
Computer doesn't recognise hardrive
It may seem obvious, but did you try a different USB port? Did you try a different computer? and did you try a different cable/cables?
Oct 03, 2012 | Freecom ToughDrive external hard drive -...
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
Windows 7 is not recognizing and comes up as a cd drive?
then check.
Jun 22, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
My external harddrive maxtor 160 GB is unknown device,how to fix?
Unplug, wait for some time and reconnect. If your device is still recognised as unknown device, give it for a check up. The outer casing should be faulty.
Oct 13, 2009 | Maxtor Hard Drive
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
I have to reload all drives etc but harddrive dont work i have bought a external harddrive but unable to get this to work as pc is not recognising it how do i get my recovery disc to work
remove harddrive from computer make it external by casing it then keep for scanning, if any virus found then remove it.place the **** to pc then install window XP again, then it will detect
Jun 18, 2009 | Computers & Internet
Dropped the 'My Book Essential' 500MB, now doesn't work
ok wow i dont even think i dropped mine but it doesnt work.. like the light flashes when i plug it in but then it isnt recognised...
Feb 03, 2009 | Western Digital My Book Essential 500GB...
Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Feb 25, 2008 | Toshiba 120GB USB 2.0 Portable External...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
