Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
This is our second whirlpool gold top freezer unit!
This is our second whirlppol gold top freezer unit in 60 days. We are still having the same issue with the ice buildup in the freezer. Is this a known issue? We are probably returning this unit and go with a different mfr. Two refrigerators, two problems and same issue! Repairman actually caulked around freezer on a brand new unit. Unbelievable.
Bruce
    Scholar:
  • 56 Answers
This may not be the problem now but by the sound of the malfunctioning unit, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
I have a Whirlpool Gold freezer top refridgerator. Over the last couple of weeks the freezer has built up an awful lot of frost. There is nothing in the troubleshooting part of the manual that addresses...
Most likely a deforst issue, having to do with either the Defrost thermostat or the Defrost timer, given that this unit is not the newer style with the control board instead of the timer. Anymore questions feel free to ask.
Nov 30, 2010 | Whirlpool Refrigerators
Hi, I have a whirlpool gold side by side fridge/freezer. I came home the other day and water all over the floor. I opened the freezer and it wasd hot. Opened the fridge, same thing. Light and fan work and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Whirlpool Gold GR2FHMXPQ 21.6 Cu. Ft....
Top half of frig. and freezer not cold .Whirlpool gold series side by side . bottom half is cold what do you think it could be?
Good day,
On a side by side machine, that is almost always the fan motor in the freezer compartment not working.
When you open the freezer door, you should be able to hear it run.
If not, you can access the motor by removing the rear panel in the freezer panel and inspect.
If it needs replaced it is a simple nuts and bolts repair.
Dec 01, 2009 | Whirlpool Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool Gold GS5SHG Refrig/Freezer trips gfci
Sounds like the condesor coil fan motor went bad and shorted in the windings or stator. It can be replaced fairly easily. You can get the mtor from one of the online part stores and install through the base of the unit next to the compressor. you should clean the area of lint while your down there, it helps keep it operating more efficiently.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jun 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge frozen
hi thanks for the question yes would replace the thermostat thanks the appliance doc
Aug 08, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Aug 01, 2008 | Whirlpool Freezers
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
