Question about Hunter 20479 The Stratford II Ceiling Fan
Stratford model fan - a grinding noise and no high speed
The Hunter Stratford Ceiling fan has been installed and running without noise or any problems for 6 months and then just yesterday a grinding sound started and there is no high speed anymore. When you pull the chain to start the fan a grinding noise is made and the blades turn slowly. When changing to the medium gear the speed increases but the grinding remains and finally low gear speed seems normal but the grinding sound is still there. What is causing this? The fan is only seen 6 months of use...
Crossedwires
  • 44 Answers
SOURCE: blade problem
The Hunter web site should have them. If not I have found simular ones at Radio Shack and also have ordered them from parts suppliers like Mouser, Digi-key, Allied electronics Mat electronics. All of which can be found and ordered from online.
Posted on Feb 09, 2008
dontdiy
  • 8 Answers
SOURCE: Hunter ceiling speed.
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
Posted on Dec 26, 2008
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
  • 1114 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Posted on Jul 21, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
I just replaced the switch in my hunter ceiling fan. I put L - black; 1 - gray; 2 - brown; 3 - green. Now the problem is that it won't turn off. I just have 3 speeds that go faster. This is not...
You got the wrong switch!!!! Just because it looks the same on the outside(switch) doesn't mean it's the same on the inside. Call 1-888-830-1326 with your model # and order the correct switch.
The model # will be 5 digits starting with a 2
Aug 17, 2013 | Hunter 20761 52'' The Stratford II Brushed...
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
After installation the whole fan wobbles. it is standard installation
The most important thing about installing a ceiling fan is to use the proper ceiling box, one that is approved and very firmly fastened to the ceiling joists. If this is not done and the fan is only attached to an existing ceiling box, it may end up being out of balance and wobbling, not to mention being very dangerous.
Sep 08, 2010 | Hunter 20479 The Stratford II Ceiling Fan
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Lightning causes ceiling fan to make clicking noise
sounds like surge shorting
call in an electrician to check the installation of the unit
Aug 06, 2017 | Hunter 20761 52'' The Stratford II Brushed...
Fan makes grinding noise when on speeds two and three. . . sounds fine on slow
The bearings are wearing out, speeds two and three are exerting enough force that the bearings are grinding, slow speed does not have enough force to do this. Soon enough, slow speed will make that noise and the fan will ultimately stop working. Have an electrician come in to look at it, if it is still under warranty, call Hunter.
Sep 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Hunter 20479 The Stratford II Ceiling Fan Logo
69 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
