59 C0 error on hp color laserjet 5550
Can you please suggest a solution for the above error on my printer urgently
  • Anonymous May 26, 2009
    59.co printer error to continue turn off than on
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
Posted on Mar 29, 2009
Dear,
kindly help me, we have one hp color laserjet 5550 i found the problem 59.0 error i want solve this case very urgent.
best regards.
sudhin
Posted on Jun 09, 2009
HP Lasserjet color printer shows the error printer 59.C0 please advise asap how to solve it
need help urgent
Posted on Mar 21, 2010
  • 3 Answers
I had the same error, I had to take the left side cover off, (looking at the front of the machine) and found a small piece of paper that ended up right in the middle of a sensor flag! Of ALL the places to land. I pulled it out, it worked, end of problem! When you get the side cover off, the sensor flag is located in the middle/bottom of the printer. Hope this helps, happy fixin'.
Posted on Sep 08, 2008
I had the same error,but i have try all the possible means but it is not working....
Posted on Nov 08, 2008
  • 1,218 Answers
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps. The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly. The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. get more help for Printer Error Code 59 C0
Posted on Sep 16, 2010
    New Friend:
Just had a 59.a0 error on a CLJ 5550. the was the tiniest scrap of paper in the female connector to the right hand side of the toner cartridges. when that was removed the printer was ok.
Posted on Mar 13, 2013
    Problem Solver:
  • 12 Answers
The Top Slot / Black color Laser Scanner is bad be sure to run a full calibration through the control panel once it is replaced for
best print quality.
Posted on Nov 22, 2009
Per the manual you have an developing disengaging motor
rotation error
the fix is
Developing disengaging motor
error
1. Reconnect the connectors
J16 for the developing
disengaging motor and J1100
for the DC controller PCB.
2. Replace the developing
disengaging drive assembly.
3. Replace the DC controller
PCB. Calibrate the printer
after replacing the DC
controller.
Posted on May 02, 2008
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
Mar 28, 2012 | Office Equipment & Supplies
Error code display 00007 in ir 3300 canon copier since i have checked fuser unit thoroughly and changed the fuser flim roll of fixing unit still then the error code display manually and after switch ON...
as you probably now, the E007 is error for fixing film rotation. The rotation is checked over sensor above the film's "white" dot.
So are You sure that sensor works, is there any left overs of old film on sensor, reconnect all connectors related to the film sensor, is the "white" spot dirty or damadged, are you sure that fixing film is rotateing properly??????????
Hope that something of this will help you to find solution....
Sep 15, 2011 | Canon imageRUNNER C3200 Copier
My canon pixma mp145 keeps showing error 5, i need to use this printer urgently, what should i do?
my canon pixma mp145 keeps showing error 5, i need to use this printer urgently, what should i do?
Sep 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
6A00 ERROR CODE
This error code has to do with the mechanism in the printer. There is a squeegie like piece that slides back and forth that will get stuck if the printer isn't used for a while. The ink on it can act like a glue once it has dried.
To unstick it, open the door of the printer so the cartridges move to the center like you were going to change out a cartridge then unplug the printer. Now look to the side where the squeegie like piece is. It should just take gentle pressure to get it to slide. Also make sure there isn't a small piece of paper in there preventing it from moving.
Plug the printer back in and the problem should be fixed.
Jan 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
URG - paper jam - Epson Stylus DX8450
Just do it! don't worry about the ink, get the paper out, then see what happens. Get a torch and poke around , have A GOOD LOOK inside
Mar 17, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Urgent printing!
Replace color cartridge so the printer doesn't consider it an error. You can print grayscale only in your print settings.
Nov 02, 2008 | HP DeskJet 970cse InkJet Printer
ERROR MESSAGE APPEAR AFTER PRINTER PREPARATION OCURING. THE ERROR MESSSAGE THAT APPEAR , INK SYSTEM FAILURE. INK SYSTEM HAS FAILED. UNABLE TO COPY, RCEIVE FAXES OR PRINT. REFER TO DOCUMENTATION. ERROR...
Ink System Failure is a Hardware Issue, which indicates that the Ink Delivery system failed to initialize.
I suggest you to perform the below the troubleshooting steps, if it doesnt fixes, then the printer need to be serviced or replaced.
1.Turn OFF the printer, unplug the power cable and the USB from the printer.Then Press and Hold the ON/OFF button for 1 minute and then reconnect the cables and try again.If it doesnt fixes, goto next step.
2.Remove the ink cartridges, Turn the printer OFF and Unplug all the cables from the back of the printer.Connect the Printer directly to the wall outlet.Turn it on and wait until u get a prompt to insert the ink cartridges.If it didnt work, go to step 3.
3.Remove the ink cartridges again and close the access door.Disconnect the power cable while the printer is ON.Now Press and Hold the OK and CANCEL button.While Holding the OK and CANCEL button insert the power cable and continue holding the button until u get a message "NVM Reset" or untill the printer goes OFF.Then release the buttons and press ON/OFF button.
4.If you still get the same error, then the printer needs to be serviced.
Thanks
Riz
Apr 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP PHOTOSMART 7180 ALL IN ONE
how to reduce the baud rate in all in one printer
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
17,018 people viewed this question
jasbo
jasbo
