Question about Kitchen Ranges
How to turn on leisure chef centre 110 oven, Have just moved into a house & have no instructions for this cooker. The grill & the hob ignite, but not the main oven/s
5 Suggested Answers
  • 183 Answers
SOURCE: The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Posted on Jul 28, 2007
jumptrout51
  • 3361 Answers
SOURCE: Oven ignition: gas goes out as soon as control knob is released
Replace the oven thermocouple.
Posted on Mar 15, 2009
  • 149 Answers
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Posted on Mar 27, 2010
SOURCE: Have a Leisure roma 100 cooker model number
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Posted on Jul 24, 2010
Hobs all working oven not working
Hob stopped working, oven still fine on electric cooker, any ideas ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comDec 25, 2010 - From this point, we'll assume that you are happy to receive all .... have a "problem" that covers the hob not working but the oven doing so. Gas Hob Ignition Not Working!
May 22, 2007
Oven not heating - Please help
Oct 14, 2006
Oven won't get hot - help please
Aug 24, 2006
More results from forums.moneysavingexpert.com
How to Diagnose a Fault With an Electric Hob ' eSpares
www.espares.co.uk > Advice Centre
Jan 01, 2016 | Logik LFTC60W12 White 60 cm Electric...
Leisure rangemaster 110
The switch may be faulty, turn off the power then remove the knob ,it just pulls off and shine a torch in to see if it looks burnt, also smell it often if the switch burns they have a distinct acrid smell.
May 07, 2014 | Kitchen Ranges
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Severely reduced gas supply to hobs while grill
Valve at back of cooker that isolates gas to the hobs when the lid is lowered is sticking. Move lid up and down half a dozen times or oil it to ease it.
Dec 27, 2009 | Cooktops
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Kitchen Ranges Logo
239 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
