Question about Mtd Garden
MTD RIDE ON LAWN MOWER SOLENOID
LOOKING FOR A WIRING DIAGRAM/USER MANUAL FOR MTD RIDE ON LAWN MOWER 13A1762F600. HAVING PROBLEMS WITH THE SOLENOID
CHANGE DRIVE BELTS
Posted on Nov 09, 2010
  • Bill Davis Jul 25, 2013
    What does drive belts have to do with motor turning over?
MTD 908 RIDE ON lawn mower belt diagram
If your manual doesn't cover this then contact MTD
Aug 19, 2014 | Mtd Garden
Greenfiled ride mower 13hp
the mesh cover should have screws in it or the center cup holds it in place. youll have to remove center nut or bolt to get flywheel off
May 26, 2014 | Mtd Garden
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mtd riding lawn mower with B & S engine i need diagram of wiring harnes conections etc.
Most owner's manual have a wiring in them. I'll try to send you a my picture. See you later.
Dec 20, 2011 | Mtd Garden
I need a diagram showing how to put the drive belt back on a riding lawn mower MTD model 13A869F190
I'm having trouble with the number you provided. Please revisit your mower and obtain the model number and serial number, then click on this link:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10301&LeftNav=true&langId=-1#
Type in your info to obtain your users manual for your mower. It should contain the belt routing diagram you're looking for.
Hope this helps... Good luck!
Aug 06, 2009 | Mtd Garden
Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Jun 18, 2009 | Boating
STARTING PROBLEMS
Either the igniton is bad or the wires are backwards. You can bypass the ignition and touch the wires together to see if the solenoid turns. You can also use an ohmmeter/voltmeter to check the current.
May 22, 2009 | Mtd Garden
Can you point me to the wiring diagram for the above mower
The flywheel black (negative) and red (positive) wires are the magneto output. Red goes to ignition to charge the battery, and also burn the headlights -- so the red will go to the headlight switch as well, maybe through the ignition.
There should be an in-line fuse on the charging/headlight wire coming from the magneto.
There should be a safety switch under the seat which energizes the fuel cutoff solenoid on the bottom of the carburetor.
There are also interlock switches on blade engage mechanism, and the brake pedal, These prevent engine from starting if brake is not applied or if blades are engaged -- these would control current to the ignition module.
This is not complete, but it'll give you some clues -- good luck -- it's a ton of work.
May 08, 2009 | Mtd Garden
Garden Logo
1,899 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
