Question about Microsoft Windows 98 for PC
Folder options not available in windows 98
Dear all,
i have a machine with windows 98 Se. I didn't get the folder options.
Pls heklp us to solve .
regards,
C.Sacthivel
  • sacthi Jan 10, 2009
    Thank you
  • 74 Answers
Plz go to run
give command
REGEDIT
then go to
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
in right side panel u get
NOFOLDEROPTIONS
DELETE THE KEY.
UR'S KISHORE CHOWDARY.
+919441133420
Posted on Apr 10, 2008
  • 76 Answers
Hi go to Display Properties next settings see folder Options ok by any Problem 919849073383 by this is uday @@@@@@@
Posted on Apr 18, 2008
I need the drivers that have to be installed in the process of installing windows 98 se
The drivers that are required are completely dependent on the hardware that you're installing the OS on. The OS itself comes with almost all the drivers it needs in order to have basic functionality. The easiest thing to try would be to go to the manufacturer's website and search their support section for driver downloads. Select the model computer you're reinstalling on and it should allow you to select which version OS you're installing. Pick Windows 98 if it's available. If it's not you'll have to resort to Google, but it would be possible that they didn't make Windows 98 compatible drivers for that particular hardware.
Jun 13, 2011 | Computers & Internet
Hi:) i tried to refomat my comp and now it goes
try and us a older win 98 boot disc or a bootable cd win98 use the fdisk option delete the existing partion..then install your operating system cd and when it says press any key to boot from cd do that and go from there..it will recreat partion and format it..i hope that heklps
Nov 07, 2009 | HP Compaq dx2200 PC Desktop
I am trying to install WIN 98 se in a Toshiba Satellite Pro TE2000. I am trying to find a Video Driver : TRIDENT VIDEO ACCELERATOR CYBERBLADE FOR WINDOWS 98 SE. Is this driver available and if so...
Use this Driver
http://dw.com.com/redir?&destUrl=http%3A%2F%2Fdata.versiontracker.com%2Fdrivers%2Fmanual%2Ftoshiba%2Fdisplay-20080310153328.zip&edId=1174&lop=feed.dl&siteId=4&part=dlint&pid=514988&subj=intfeed
Hope this help
Cheers!!!!
Jul 22, 2009 | Microsoft Windows 98 for PC
98 SE installation
no downloads available.
you can buy it or I can send you a ISO image. which you have to make a CD from that.
if that you can do then, repost it here.
May 14, 2009 | Microsoft Windows 98 for PC
Windows 98 se, xp not installed to compaq armada E500 pc notebook
First, format the hard drive and make sure it is in FAT or FAT32 for Windows 98 install. Then do your partitioning etc and should work. If it doesn't, it is possibly a hardware fault.
Here is the site for the drivers for the laptop :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=1093
Hope this helps in some way :)
Jan 05, 2009 | Compaq Armada E500 Notebook
Usb 2.0 windows 98
Windows 98 SE supports USB 2.0. The original Windows 98 (gold) or Windows 98 OEM or Windows 98 Upgrade versions which are not SE will not support USB 2.0. Nor is there any way to get USB 2.0 support for these Windows 98 versions unless you upgrade to Windows 98 SE.
Note that the Windows 98 SE upgrade CD will fail upon completion, leaving the SE Upgrade with a corrupt registry, if you try to run the Windows 98 SE Upgrade CD on a Windows 98 system that has a version of IE installed which is higher than IE 4.
Jul 02, 2008 | APC USB Port Version For Windows 98...
Folder option hide in xp
open my computer... at tools menu click folder options... then click view tab and click the button show all hidden files and folders...
Jan 21, 2008 | Microsoft Windows 98 for PC
Hidden files
When you open the window "My Computer" you need to open the "Folder options". under "Folder Options" you have three tabs, you need to click on the "View" tab.
Under "View" tab you have an option as "Hidden files and folders", you may select the option according to your choice over there.
Note : - In win XP the "Folder options" are present under the "Tools" tab, however it might be under the "View" tab in the "my computer" in win 98. I don't have a Win 98 handy to check that. i am sure you would be able to find that out. Once you have the "Folder options" the steps are same as mentioned above.
Hope that resolves your issue. Will wait for tee rating.
Thanks
Sammy
Dec 05, 2007 | Computers & Internet
Trouble shooting
ya its asking the windows 98 cd key
try this
Follow the steps below to locate your Windows 98 product key code from the Windows 98 registry.
Difficulty: Easy Time Required: Less than 10 minutes Here's How:
  1. Click on Start and then Run.
  2. In the text box in the Run window, type regedit and click OK. This will open the Registry Editor program.
    Note: Do not make any changes to any entry anywhere in Registry Editor to avoid causing serious system issues. These steps only direct you to view entries, not to make changes.
  3. Locate the HKEY_LOCAL_MACHINE folder under My Computer and click on the (+) sign next the folder name to expand the folder.
  4. In the resulting folders, locate and click on the (+) sign next to Software to expand this folder.
  5. In the resulting folders, locate and click on the (+) sign next to Microsoft to expand this folder.
  6. In the resulting folders, locate and click on the (+) sign next to Windows to expand this folder.
  7. In the resulting folders, locate and click on the Current Version folder.
  8. In the results that appear in the window on the right, locate the ProductID.
  9. The numbers and letters on this line represent the Windows 98 product key. The product key should be formatted like xxxxx-xxxxx-xxxxx-xxxxx-xxxxx - five sets of five letters and numbers.
  10. Write this product key down exactly as it is found here for use when reinstalling Windows 98.
    Note: If even one character is written down incorrectly, the installation of Windows 98 that you attempt with this product key will fail. Be sure to transcribe the key exactly.
  11. Close Registry Editor without making any changes.
Tips:
  1. If your system was purchased with Microsoft Windows pre-installed, and you have not reinstalled it or upgraded it yourself, the product key found by the steps on this page will only find the generic product key that your computer manufacturer used to install the operating system. This product key will not work when attempting to reinstall Windows. In this case, you must use the unique product key that is on the sticker attached to your computer case.
  2. rate me solved if its helps thx
Nov 21, 2007 | Microsoft Windows 98 for PC
Problem with my video card and sound card
No, that card is not compatible with Windows 98 or Windows 98 SE (Second Edition). It is only compatible with Windows 2000/XP/XPx64/MCE.
Compatibility meaning there are no drivers available for Windows 98/98SE.
Oct 15, 2007 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
369 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
