Question about Whirlpool LGN2000LWH Gas Dryer
Whirlpool dryer wont heat>replace igniter > no heat
    President:
  • 512 Answers
Bad thermo switch located behind back cover in area of duct work. 1/4"x2" white in color, two wires connected to it. Stops ignition from firing.
Posted on Jun 07, 2010
3 Suggested Answers
  • 13 Answers
SOURCE: dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Posted on Dec 19, 2008
marka19
  • 1430 Answers
SOURCE: Whirlpool LGN2000LW0 Dryer will not heat
The problem is more likely a thermal fuse or thermal cut out. Here is a video that walks you thru testing these http://appliancehelponline.com/gdryertroublevideo.html
http://appliancehelponline.com/gdryertroubleshootge.html
You can also enter your model # for diagrams and illustrations of your specific model.
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Dryer starts heats up then burner drops out igniter will try to relite but wont
Make sure that you check to see that the valve is not shutting the gas off to the igniter. If the igniter / pilot goes on and off itself then there is an issue with the ignitor / pilot and it will need to be replace.
Jul 02, 2012 | Whirlpool Dryers
Whirlpool lgn2000LG0.... flame wont ignite.. glow stem glows..
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 04, 2011 | Whirlpool LGN2000LWH Gas Dryer
Wont heat up ignites but doesnt stay on
the igniter is probably not hot enough, it needs to glow white hot. if it is orange it needs to be replaced. hope this helps.
Oct 13, 2009 | Whirlpool TGDX640P Dryer
Whirlpool Estate Dryer TGDS840JQ1 dryer runs but does not heat up to dry the clothes.
when you say heat up is it at least getting warm...
you may have a igniter gone bad or your thermostat may have failed... your igniter is what has to ignite the gas to burn to make it hot. If its electric then your heating coil has failed and needs to be replaced
Jun 08, 2009 | Whirlpool Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Why dosent my dryer get heat
There is a sensor for detecting airflow. If the dryer is unable to exhaust properly it will shut down the heat for safety reasons. Be sure the exhaust vent is not obstructed, and that there is good exhaust air flow. If there is insufficient exhaust, find and correct that condition.
Hope this helps.
Mar 28, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool LGN2000LWH Gas Dryer Logo
164 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
