Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer door popped open during cycle; door will not latch closed; can see something plastic in the hole where the latch fits;
  • 35 Answers
May be the latch was brocken replace the latch
Posted on Jun 06, 2010
I have a Whirlpool GHW9400PL0 front loading washer. The door won't stay closed, and I think it's because the plastic latch on the base of the machine broke. The latch portion (white plastic) looks...
you have to inspect that switch carefully,, its actually got 2 , a secondary switch latches just before the spin cycle, I'll try and locate the part for you
Jul 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Door popped open during the wash cycle and now will not close
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Mar 08, 2009 | Kenmore Washing Machines
Whirlpool gold door falls open during cycle
You can probably get away with getting just hinges for the door if it is not bent also check the latch if it doesn't look broken the just go for the hinges.
Jan 11, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Door won't close now
I can tell you where the door latch release is.
Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on towards the bottom) Once you have that panel removed, reach up just behind where you see the openings for the door latch. the black square hole and black round hol are all part of a larger door latch mechanisim. At the bottom of this mechanisim (cloest to where your hand will be) there is a "tab hanging off the bottom". Pull on the tab for a manual door release.
Please make sure if you found this solution helkful to make sure you rate it. Best of luck with it and drop me a note if you have any other troubles.
Jul 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Broken door
You probably have to bad door latch. its easy to replace. it requires i believe a number 20 torx bit you have have to remove the spring around the door boot and then you can put you hands to inside the unit to remove the latch.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
