Question about LG Xenon GR500 Cell Phone
Screen wont convert to text by keyboard. The screen stays on the vertical and will not let me text by the horizontal keyboard.
  • marjorie_ols Jun 06, 2010
    Taking the battery out for 30 minutes did not fix the problem
  • 1,284 Answers
Hi, the problem simply is the flex of the phone, which is the mechanism that is connecting the screen to the keypad of the phone.
It may sometimes work when the mechanism connects a little, that is why you can type on the keypad. It's quite difficult fixing it on your own, but if you want to, you will have to get a replacement flex, get the appropriate screw driver that matches the screws on the phone, carefully unscrew the parts of the phone. Locate the flex & replace it with the replacement flex you have with you,
Carefully screw it back together and you will find your phone in good condition again, or better still you can take the phone to an expert for repair.
Take care
Posted on Jun 06, 2010
  • 713 Answers
Hi,the problem is associated with a jam on the operating system,i will suggest you turn off the phone and remove the battery,afterwards,insert the battery after 25mins at least,
turn on the phone,and the problem is solved,if the problem remains,it means the firmware of the phone needs to be flashed to restore the phone back to a normal working condition.
Thanks and take care
  • Oyelade Gbenga Jun 06, 2010
    It means the ROM(random operating memory) of the phone needs to be flashed,this restores the factory setting of the phone,this is the only lasting sollution to your problem.
    Good luck
Please keep my screen from rotating on my ipad.
Swipe your finger up from the bottom of the screen so it displays the controls. The one at top right with a padlock in a circle with an arrow in the clockwise direction is the orientation lock. Tap it once to lock.
Jun 07, 2015 | GSI Wireless Mini Bluetooth Keyboard For...
How to calibrate galaxy mini 2 S6500
Have you tried this?
Go to Menu - Settings - Language & Keyboard - Touch Input - Text Input. Then choose either Calibration Tool or Reset calibration
Jun 19, 2014 | Samsung Computers & Internet
When I open the keypad to use the keyboard, the phone screen stays in the vertical position rather than flipping to the horizontal position. what to do??
The flex cable of your phone between the keyboard and screen may be disconnected or needs to be replaced, which enables the screen flips when the keyboard is brought up. The best step here is to take it to the LG repair shop and get it mended. Though you can it is difficult to repair it yourself, you can use appropriate screwdrivers for the screws of the phone, find the flex cable and fix it. Close the phone just the way you opened it.
Nov 17, 2010 | LG Xenon GR500 Cell Phone
Trackball does not work, when you press down it will not select anything so you cant open text or any menus.
Cause:
The sensitivity of the trackball/trackwheel might be less
Faulty Hardware
Resolution:
Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100
Aug 12, 2009 | RIM BlackBerry Pearl 8100
When I flip the phone, the screen stays on the vertical view
My daughters phone had the same problem. It turned out that my very magnetic purse (which I had put her phone in) messed it up. I took the phone and reran it over the battery vertically and horizontally and it started to work instantly. I guess the phones are very sensitive to magnets (purses, money clips, phone cases/holster holders) so be careful. Hope this helps!!!
Jul 19, 2009 | LG Xenon GR500 Cell Phone
Monitor has all in a horizontal position,want vertical
do you mean the task bars? if so click on them and drag them back down to the bottom of the screen
Sep 03, 2008 | Logitech 967437-0403 Keyboard
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Logitech Access Keyboard problem
Typeing with the Logit. keyboard shows no letters on my Gateway screen. Changed batteries. Arrow works appropriately, but no letters seenon the Gateway scree.
Nov 25, 2007 | Logitech Deluxe Access Keyboard
Weird TV
the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Oct 06, 2007 | Panasonic CT25G7 25" TV
LG Xenon GR500 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
