Question about Magic Chef MCD1311ST Microwave Oven
When heating their sometimes what looks like a sparking in the part where the electric coponent are but probably not tube because it still heats. It doesn't do it right away when u turn on but after a few seconds. I did cook a lot of cereal in it which causes alot of moisture and maybe that could have damaged something.
  • larryj305 Jun 06, 2010
    The sparking is not in the food compartment. If u are looking at the microwave and can picture the clock and key pad it is in that compartment but near the rear but u can see it when microwave is on, through the glass and on the right panel where the little screen area is.
    President:
  • 2,702 Answers
Your not going to like me for this answer,,,its inside your microwave the sparking is coming from???
well when they do this its normaly down to one thing
its the damp getting into the works of the microwave and very soon there is going to be a "big pop" or a "bang" and that will be the end of this microwave,,,
it must be getting a bit long in the tooth by now to start this,,so take my hint and start saving your money up for a new unit,,,oh,,by the way,,,,they realy do go with a bang and heeps of smoke at times????
but on the other hand it could just go with a wimper!
Posted on Jun 06, 2010
Micowave runs but doe not heat.
If it looks and sounds like it's running but doesn't heat, one possibility is that the magnetron tube has burned out. This is the electronic tube that emits the microwave radiation. Another possibility is that the control circuit that regulates turning the magnetron tube on and off for defrosting and lower-than-100-percent heating rates could be faulty. Try heating with the defrost setting and at full power and see if either method results in any heating. The cost of replacing the magnetron at a repair shop could be high enough that you might rather just buy a new microwave oven. My father replaced the magnetron tube himself, but he's an electronic engineer. I wouldn't recommend that just anyone try it. How new/old is it?
Mar 10, 2015 | Microwave Ovens
Microwave won't heat, timer goes off after 1 minute or so
Microwaves are a quick, convenient solution to the hassle of preparing and cooking hot dinners. They are popular appliances with students and large families where food often needs to be prepared fast. Microwaves use radio wave technology harnessed through an antenna, known as a "magnetron," to create friction between food or liquid molecules, causing them to heat up. Some microwaves can cease to function properly, resulting in the appliance running but failing to produce any heat.
  1. Magnetron
    • Magnetron tubes are often the source of heating problems in microwaves. Before having any repair work done, check the warranty on your microwave. Many companies offer 10-year warranties on magnetron tubes so you may be able to get it repaired professionally for free. Otherwise, unplug the microwave then remove the rear casing with a screwdriver. Locate the tube inside the microwave and check it for burn marks. A burnt tube cannot usually be repaired and will require replacement. A tube that doesn't appear burnt should be tested by a qualified technician to see if it can be repaired.
    High Voltage Capacitor
    • A microwave capacitor holds electricity as the appliance is running. A malfunctioning capacitor can lead to the microwave not heating, along with an irritating buzzing sound. Test the capacitor by first disconnecting the power then removing the wires attached to the capacitor. A capacitor with burn marks is usually damaged beyond repair and will require replacement. A capacitor can be tested by connecting each of the probes of an ohmmeter to the capacitor terminal. Each probe should provide a reading of infinity if the capacitor is working properly.
    Power Diode
    • The diode in a microwave oven is a one-way pathway that channels electricity from the capacitor. A malfunctioning diode can sometimes be the cause of a microwave that won't heat. The heating problem is often accompanied by a loud buzzing noise. You can test the diode by first unplugging the microwave oven, disconnecting the diode from the capacitor then measuring the level of electricity inside the diode with an ohmmeter. The ohmmeter can determine whether the electricity in the diode is flowing in one direction as it should. In most cases, the magnetron tube will have to replaced as well if the diode is damaged.
    Safety
    • Disconnecting the plug from your microwave to carry out an inspection does not guarantee safety. Even an unplugged microwave still has electricity running through its components, which can lead to severe electric shocks. Unless you have previous experience in dealing with electrical appliances, it is advisable to hire a technician to test component parts rather than undertake the job yourself. Anyone without a basic knowledge of electrical currents and safety should avoid testing components altogether.
Oct 03, 2011 | Microwave Ovens
Turned it on to heat food and make a loud noise , did not heat food and have electrical short ordor.
there is something metal inside that is causing this look for any screws or anything that may have been switch with a repair. what happens is the metal causes the microwaves to reflect back to the magnetron instead inside the food causing noises and sometimes sparks and odor. find the metal object remove it and this should solve your problem
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works just dose not heat anything
There are several possible reasons, but the most common is failure of the magnetron tube, the microwave source. These wear out over time and when they fail, there's no heating any more. Sometimes they just quit, and other times they go with sparking and burning smells.
The magnetron is replaceable, but it's costly. With labor, the repair is likely to cost more than many new ovens. If this is a basic counter-top model you should probably just replace it. For higher-end models it may be worth having the oven checked and getting an estimate. Since there are other possible causes, repair might be economical.
Apr 06, 2010 | Microwave Ovens
Microwave running like normal but not heating food?
A part called the magnetron tube makes the microwaves, and either the tube has gone bad or it's not getting power for some reason. If you noticed any strange sounds, sparking or funny smells before the oven quit heating, it's safe to assume the magnetron is bad. But they can also go bad without being obvious about it.
It's also possible that there's something wrong with the control board or connections to it so it's not switching on the magnetron power. In some brands and models, door switches and safety thermostats may cause problems.
If this is a basic counter-top oven, you probably should just replace it. They're so inexpensive now that it will probably be half the cost just to get an estimate. And if it is a bad magnetron, the repair would certainly exceed replacement cost. For a high-end oven or built-in model, it might be worth getting the estimate and then deciding whether to fix or replace.
Hope this helps! Thanks for using Fixya.
Apr 03, 2010 | Microwave Ovens
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Goldstar microwave
Open the cover and look for a fuse. If it's not blown then the power tube (klystron?) is probably fried.
Mar 27, 2009 | Goldstar MV-1526 Microwave Oven
Microwave, adora, stopped heating
Hi and welcome to FixYa,
Almost always, on most microwave including GE Adora, no heat with all else working indicates a problem with the magnetron. Since the magnetron produces high RF energy and operates on high voltage, it would be to your advantage to seek the services of a qualified professional.
If on the other hand, the fault of no heat is coupled with no display, error messages, door not locking, no light, then it would be possible for a DIY (do-it-yourself) repair. All that is required is a bit of familiarity with electronic components and circuitry, the use of a DVM/VOM of course safe working practices when repairing electrically powered devices.
Pls post back any other symptoms or indicators other than 'no heat'.
Good luck and thank you for using FixYa.
Mar 14, 2009 | GE Adora DVM1850 Microwave Oven
JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Mar 05, 2008 | GE JVM2050 Microwave Oven
Magic Chef MCD1311ST Microwave Oven Logo
109 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
