Question about Canon PIXMA MP530 All-In-One InkJet Printer
Jun 06, 2010 - This printer should move to the center of the carrage once printer is opened to change ink for example. I have to manually move it and it does not move back to position when you close the printer or even if you power on on off the printer the check printer message comes up with code 5110.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip (encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply. Please do accept the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
How do I clear a carriage jam when cartridges do not move along when lid is opened?
Hi, hope.I can give you a hand. Once you turn on the unit, check too see if you can get to the menu prompt. If you can, go into the cartridge change part of the menu. Say yes to any question about removing the cartridge. Then go thru full procedure. What is holding third cartridge in is a lock down for security. Hope this helps. Let me know. Thanks.
Mar 21, 2015 | Office Equipment & Supplies
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
Have an Epson NX200. Need to change ink cartridge but ink carrier will not position so I can open it.
usually you can move it manually with your hands .Turn off first your printer .once it turns off pull the carrier, pull the white tape gently to the center and just replace it ink cartridges there. Make sure its properly plug in .Once your done return the move the cartridge carrier manually from left to right 5x once your done you may now close the cover .(close it first ) And checked if its going to the center once you open the cover .
Hope it help thanks
May 26, 2011 | Epson Stylus NX200 Printer
HP5550 INKJET PRINTER NEEDS INK CHANGE AND DEVICE TO PLACE THE INK IS NOT MOVING TO THE CENTER.
Just open the top of the printer and manually grab the device and move it to the center. Then take out the ink and place the new ink in. Remember to take the protective strip off the new ink.
Hope this helps, give me thumbs up please.
Aug 23, 2010 | HP DeskJet 5550 InkJet Printer
Carridge won't come far enough across to allow for cartridges to be changed
Hello there
turn off the power and you can manually pull the carrage to the center than after you change the cartridges out just power it back up and it will reagline it's self ok
best regards mike
Aug 05, 2009 | Epson Stylus C46 InkJet Printer
Epson c20ux -ink cartridges installation
Power on
Open door or front top of cover that covers cartridges.
Systen should move ink carrage to center so you can take out old and put in new.
Close door/cover and should get some data on Monitor to follow so system recognizes new cartridges.
If no work u have some type of a problem in printer.
I'm assuming you don't have a paper jam or anything. If you do must clear.
Luck
JC
Jan 18, 2009 | Epson Stylus C20UX InkJet Printer
Epson SX200 Can't get the ink carrage to addopt change position
i had the same problem as this.
the manuel told me to put the ink in the printer before i had installed it, this however seems impossible.
instal your printer first. when it is instaled go to printer settings, then click on maintenance, then click on the option that says ink cartridge replacement. Follow the instructions and this will bring the cartridge to the change position!!
failing this you can unplug your printer quickly after you turn it on when the cartridges move, then you can manualy move into position. Not sure how good for your printer this is, but it works.
Jan 03, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How do I access the ink jets?
You must open up the printer. The lift point is in the front between the paper output and glass scanning surface. You should see and indent there . When you lift it up (it does weigh a slight bit), the printer heads should move to the access position. There is a lever on top of each cartridge to unlock it front the carrage.
Oct 06, 2008 | HP PSC 750xi All-In-One InkJet Printer
Print cartages won't move when I open to change.
You can manually move a printhead( the one that holds the cartridges) to the center. Open the door at the back, turn the wheels clockwise, and while turning, manually move the printhead to the center..
Apr 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
old marine
old marine
