Question about Motorola Mobility L6 Cellular Phone
I m not able to connect my L6 to d computer - Motorola Mobility L6 Cellular Phone
How to start internet in PC using MOTOROLA L6.I have dongal.
download the Motorola L6 modem driver here.
After you download the driver, make sure extract it somewhere in your computer since I packed it in a ZIP file. Connect your Motorola L6 phone by using a USB cable until the system tray shows you the pop-up message “Found Motorola L6 Modem”. You’ll meet the “Add New Hardware Wizard” dialog box then. Follow the instructions until you told to specify an exact location for the corresponding hardware, which is your Motorola L6 phone.
When your files are located, a dialog box will warn you whether to stop or continue the installation since the driver hasn’t digitally signed by Windows. Click “Continue Anyway”, Windows will start to copy the driver files into a specific location. As the process finished, your Motorola L6 phone will automatically turn its mode to Loud and start charging the battery.
That’s all. Next thing you should do is set up your internet connection through Start > Settings > Control Panel > Network Connections. Get yourself to the Files menu and choose New connection.. You’ll be guided with a step by step New Connection Wizard.
Mar 25, 2010 | Motorola Mobility L6 Cellular Phone
I CANT BROWSE MY MOTOROLA L6 TO MY COMPUTER, WHAT DRIVER SHOULD I INSTALL?
You can download the Motorola L6 modem driver here.
After you download the driver, make sure extract it somewhere inyour computer since I packed it in a ZIP file. Connect your Motorola L6phone by using a USB cable until the system tray shows you the pop-upmessage “Found Motorola L6 Modem”. You’ll meet the “Add New HardwareWizard” dialog box then. Follow the instructions until you told tospecify an exact location for the corresponding hardware, which is yourMotorola L6 phone.
When your files are located, a dialog box will warn you whether tostop or continue the installation since the driver hasn’t digitallysigned by Windows. Click “Continue Anyway”, Windows will start to copythe driver files into a specific location. As the process finished,your Motorola L6 phone will automatically turn its mode to Loud andstart charging the battery.
Jul 21, 2009 | Motorola Mobility L6 Cellular Phone
When i connect my motorola L 6 with my computer with data cable it cant open it why & what can i do?
First install (on your computer) the software that came with it on a CD in the box. Then connect the L6 with the data cable
Jun 22, 2009 | Motorola Mobility L6 Cellular Phone
How to transfer java application to Motorola L6?
if you have java file then u do not need software.
first you download the .jar file of l6 and copy to other mobile.
second you connect with bluetooth other mobile to your l6 and send .jar file to l6 then you download java application.
Jun 18, 2009 | Motorola Mobility L6 Cellular Phone
Connect Motorola l6 and PC
i cant find the software of L6 that can copy the songs in the mobile ihave cable but could not find the driver.Tell how can find the software.Please it urgent.
Feb 03, 2009 | Motorola Mobility L6 Cellular Phone
Can't connetc to pc my motorola l6
have you got the soft wear to run you usb if you dont when you connect it up it will ask to insert soft wear or you can retreve from the internet then follow the instruction.
Sep 18, 2008 | Motorola Mobility L6 Cellular Phone
Can you give me the motorola L6
you have to buy a data cable in order to connect your phone into your PC.
Jul 15, 2008 | Motorola Mobility L6 Cellular Phone
Free driver download
we need a motorola L6 driver. i want to connect my mobile because, i did not connect my mobile phone. i am used GPRS in mobile phone. but i have many problems. please sent motorola L6 driver in my id.my id is (abhishek_13101993@yahoo.co.in).
thanks,
Apr 17, 2008 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
