Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is coming from underneath..out. Or from the door...going under the washer. Help?
  • 1,531 Answers
Empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.My whirlpool duet front loader is leaking water? - f94b104.jpg
Posted on Jun 06, 2010
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Whirlpool duet front loader washer has a water leak from under the machine. What could be causing this?
Pull off the lower front panel and watch while washing . You should be able to pinpoint it .
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water keeps running through every cycle of my Duet Front Loader.
You most likely have a bad water fill valve. The suds warning is likely because it is too full.
Mar 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you soak clothes in Whirlpool Duet
front loaders don't have a soak cycle because of the very little water that they use.
use the pre-wash setting to extend the time.
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi there... My Whirlpool Duet washer has recently sprung a leak! It leaks a small stream of water out of the bottom left side (as you would look at it from the front) and runs down the stand to the floor....
I had the exact same problem on my Whirlpool front loader (model# GHW9100LW1). It turned out to be a tear in the rubber drain hose (from tub to pump). There seemed to be some debris caught up in the drain hose, and what really did the damage was a piece of metal wire that broke off one of my wife's bra straps and made a nice tear in the hose. The washer leaked out of the left side as well and down the pedestal. The drain hose only ran about $13.00. To get to the hose you will have to remove the front tub seal (bellow) and the panel just above the pedestal. While you're in there it would be good to clean out the filter cap for the drain pump as well. Good luck!
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Apr 19, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Whirlpool Duet GHW9400 Water Level Seems Too Low
Scott,
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
Apr 03, 2009 | Whirlpool GHW9400 Duet Washer
Whirlpool WFW8400TB leaking and not spinning
Send it back and get yourself a nice top loader w/o digital settings. The front loaders look good and all but i see so many unhappy post about them I myself will wash in a bucket before accepting on of the front loads free.
Apr 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Allergic to detergent for front loaders
I have always used regular Tide powder in mine and my kids use Tide liquid in it. You just need to use about half as much. My man is a motor head so he gets DIRTY and I have three teens so I wash a lot of very dirty clothes. My clothes get very clean and I have never purchased the "special" Detergent.
I have had my Duet for three years.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
335 people viewed this question
Dan Webster
Dan Webster
Sal De
