Question about Tools & Hardware - Others
Boards are difficult to get through the planer.
The infeed and out feed are soining and the blades are spinning. but the boards are difficult to pass thru. I have to push them thru. How do I adjust it to make them pass on their own?
  • 59 Answers
You may just need to wax the bottom plate of the planer. Either by rubbing with solid candle wax or maybe applieing household furniture wax paste.
Posted on Jun 06, 2010
  • gdscraft Apr 04, 2011
    The candle wax would work, or Johnson's paste wax, but some furniture polish has silicone in it which may give you a "fish-eye" problem when you put finish on the project.
Feed extremly hard to push board thru
my be you planning to much wood at once or the cutter is dull
Mar 15, 2014 | Dewalt Planer (DW734)
The infeed roller is uneven and it snipes the boards
Sniping is common, try feeding waste stock in before or after your good wood, whichever end is getting sniped. The planer will not notice the end of your wood, and cut it flat.
Oct 03, 2013 | Powermatic 1120003 PM15 Planer/Molder
Severe sniping with planer
You will always have snipe at the end of planed boards equal to the distance from your infeed and outfeed rollers. It's severity is determined by how much the board sags or dropps behind the planer until the second roller catches the board. Some planers have extended tables to help with this. What you can do is hold the board up as much as possible and still let the infeed roller move the board smoothly until the board contacts the outfeed roller.
Jan 30, 2013 | Craftsman 12 amp 12-1/2" Bench Planer...
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
I have a delta 12 1/2'' portable bench top planer, I am having feed problems with the machine. It really has not fed lumber thru it since i purchased it, Can you give me some advise on what to do make it...
Hi David, W/D here.
You have already covered the normal bases, so give this a try. When planing, cut considerably less, and see if the feed improves. It should. You should probably try this on scrap wood to get the feel of it. Measure your wood, then aim to plane no more than 1/16" on the first pass. If successful, try a bit more, say 1/8". Generally speaking, it is better to make multiple passes taking small amounts of material than to try to get it all in one pass. The wood will feed better, with less checking, and give you a better finished product.
Best regards, --W/D--
Feb 19, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
The planner nips the end of the board
My planer does the same thing.
1) I don't make the final cuts on my boards until after planing.
2) I discovered why the planer does this. I don't have a planer table. I use the two metal stands that came with the planer, and they don't really hold the board flat & steady like a planer table would. The planer has 2 rollers >>> one roller is on the feed-end and one roller is on the finished-end. When the end of the board goes past the feed-end roller, it is no longer held flat by two rollers. The weight of the board causes the board to tip up into the planer blade on the last 3 inches. So sometimes I just hold up the end of the board as it finishes ... but it still takes a nip out of the board now and then.
Up-vote if the information helped you. Thanks for the feedback.
Oct 15, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Planed board has a lower step than the rest of the board after passing thru planer , not equal amount planed off.
I think you are talking about what is commonly called "snipe". This is an inherent problem with all planers, but especially with heavier cuts. You can take lighter cuts, or you can start with a board longer than your intended finish length. You can also put the board you are planing on top of a longer board, then feeding them through together.
Sep 02, 2010 | Ryobi Thickness Planer Blades
Thickness Planer (DW733) leaves fine scratches on wood surface.
It sounds like your blade holder assy has become misaligned on the blade drive shaft. Try if you can to use a straight edge on 2 planes 90 deg apart and see if there are any gaps in either of the srtaight edges. I suspect that the blade drive holder has become slightly dislodged from the drive collar on one end allowing the blade drive to tilt on the drive shaft. I had the same thing happen on another brand named Planer and it was a matter of reseating the collar to cure the stripes. Sure took a long time to sort out. Good Luck.
Feb 06, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Dewalt735 Planer will not drive wide boards thru planer
I use denatured alcohol to clean the rollers on my Makita, and it doesn't seem to have harmed them over the years, but I do this infrequently. If your rollers are coated with pitch and or chips they won't feed well, no matter how they're adjusted.
(I don't think this planer has the capability to adjust the spring tension on the rollers, but I could be wrong.) You can consult the manual online at http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=22538&typeId=7605&documentId=21151
If you can attach dust collection to the planer it will probably help.
Also, the direction of the grain makes a difference when trying to plane boards as dense as poplar, (which has a kind of weedy, roey grain sometimes, that would prefer to tear out.)
For example, if you were feeding the board from right to left of the page, the grain on the side of the board should look like this//////// instead of this\\\\\\, which will have a tendency to tear out and jam the planer. If you can make sure the boards feed through in the right direction, this may solve your problems.
I heartily recommend the wax, as well. And possibly compressed air with a nozzle to blow chips aside.
Also consider the length of the boards and the effect of the drop weight on the planer's rollers if there is not an extension roller in place (or a worker) to hold the board as it makes its pass through the machine.
If you feed the board with the cup side down to begin with, taking light passes to smooth the top face, then flipping it over end over end and feeding the other side in the opposite direction, flattening first one face, then the other, you might have better luck.
Aside from all this, a surface planer isn't a jointer, which is designed to straighten & flatten boards, and portable planers in general won't perform as well as industrial models of the same capacity.
If you will continue to be running a lot of stock through your machine, you might want to consider investing in a used 13" Rockwell or Delta or some such cast iron planer, with rollers top and bottom to facilitate movement of course material. They aren't as portable, but might save time in the long run.
On a final note, there's no replacement for sharp knives. Even the best planer won't drive stock well when the knives get dull.
Best of luck!
Jan 18, 2009 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Planer is not feeding wood through without manual force
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
Nov 13, 2008 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Tools & Hardware - Others Logo
625 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
