Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
Had a djx700 mixer for a couple of years now,brilliant mixer when it works fully!! the latest problem is that after 30 mins + the sound drops from 1 channel also the area underneath the power supply is very very hot.
  • Behringer Master
  • 5,603 Answers
Open the unit and search for a hot chip with your finger on the failing side.
One of the chips or circuitry is likely drawing too much current. I have seen traces on a circuit board start to short out and cause this due to spillage of liquid in a mixer.
You could use circuit cooler to cool suspect chips to see if it restores. This would be a quick way to isolate bad chip.
Posted on Jun 06, 2010
Behringer djx700 has no bass
Check that all the eqs are set not to cut bass, check there are no effects on and that the XPQ is off. If you still have the problem how sure are you there is no bass coming from the mixer? Have you tried it with another amp? We had one hire customer who had the same problem you describe and his amp had a crossover and it was set to act as a mid/top amp and wasn't giving him any bass, unsurprisingly, switching it back to full range sorted it.
Dec 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
Frustration coming from djx700 mixer left Chanel need help :( on booth and master ??
the faders were actually fails functioning it well, it must be replace a new one!im a audio technician of BEHRINGER!
Aug 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have the Behringer Eurorack MX 2642A. Over 6 years old. The right main mix output sometimes works great and sometimes gets very quiet and distorted. Is it time for a new mixer or is there possibly a...
It sounds like one of the output devices is going bad, ie., output transistor, capacitor, resistor or maybe just a bad connection on one of the above menitoned items. One other problem which causes this would be the main or sub volume slider or pot is wearing out and needs to be replaced.It would definately be worth your while to have a technician trace down and fix the problem on this board. Hope this helps.
Feb 10, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Im thinking about buying a djx750 and have rokit 5 monitors. would this work? what is the best way to connect them, to have good sound? it is just for a home dj setup, all on one desk, two cd decks,...
Here is alink to the manual:http://www.behringer.com/EN/downloads/pdf/DJX750_P0956_M_EN.pdf You should have no problems hooking them up (RCA to RCA). I've been using a Behringer XenyX1222FX board in my recording system for about 4 years now and have been quite satisfied with it's reliability. Try to find a dealer who will demo the mixer for you.
Aug 24, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
My behringer djx700 does not work properly 2 use the effects u have 2 plug an rca into the booth output on the back but then nothin else works and i can only here my left turntable in my head phones there...
Semiconductor things involved with sending the booth signals into the mains are:
IC2 which is a 5241 gate controlled by MIC_ON.
IC30 4580 summer for MIC and BOOTH.
IC53 4580 inversion and gain control.
IC39 4580 MAIN output drivers.
May 13, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Aug 26, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Faulty effects behringer djx700
The effects on the PMP powered mixers flash UNTIL you push in on the selector knob. This way you can dial in the next effect number and then push in later to activate when you want it... Could yours possibly be the same technique?
May 16, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Effects button not working!!!!
Most likely the fuse for the effects circuit has blown, which happens sometimes on mixers with built in effects.
You'll have to open the mixer as the fuse will be inside the mixer on a circuit board (look around inside where the effects part of the mixer is) replace it with an identically rated working fuse and you should be done.
Apr 24, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Problem with djx700 possible overheating
Sounds like an electrolytic capacitor that has faulty electrolyte. Look for the culprit in the power supply area. It looks like a can covered in usually light or dark blue plastic. It's end may have developed a 'bulge.' This usually occurs with capacitors around 10 years of age or heavily used over a long duration, or under very hot conditions.
You may also want to make sure all solder joints in the power supply are good.
Dec 18, 2008 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
369 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
