Question about Mitsubishi WS-65711 65" Rear Projection Television
The tv will not power on
The tv powered off on its own and now will not turn back on. The green light comes on for approx. 10 seconds and screen never comes on and then it automatically shuts off again. Prior to tv going off, the picture was showing a double image and a blue line on the outside frame of picture.
  • 10,515 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input/or device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 06, 2010
  • todd_g_lee Jun 06, 2010
    ok, it blinks twice, then pause, blinks twice then pause . . .and did this over and over
  • taran_2005
    taran_2005 Jun 06, 2010
    Thanks for your response!!
    Error Code Probable Cause
    12 No error detected
    22 Recovery
    from momentary Reset
    32 Lamp Cover open
    33 Air Filter
    Cover open
    34 Lamp abnormality
    35 Chassis Fan failure
    36
    Exhaust (Back Cover) or Lamp Ballast Fan failure
    37 Engine (DMD
    or Lamp) Fan failure
    38 Excess Lamp Temperature
    39 Excess
    DMD Temperature
    41 Short Detected
    44 DVI Cable (between
    Chassis and Engine) disconnected
    This is the convergence chips gone short circuit
    You can do it yourself if your practicable enough
    The chips themselves are of the STK variety mounted on large heatsinks unmistakable on the deflection board.
    Looks like the above but as I say mounted on the heatsinks
    Here is a good article about the solution with a pioneer model but very relevant to yours as the same idea is used throughout
    http://home.earthlink.net/~oleg.filippov... it does mention the convergence being off,but is relevent to your fault too as yours have gone short tripping the set
    In the manual you have it clearly points to were the chips are on the page 18
    IC8C01 /IC8C02
    You can obtain the ICs from
    www.partstore.com
    www.encompassparts.com
    They are about $50 each
    You also need to check ALL the pico fuses and low ohm fusible resistors around the chips before power up and replace if necesary
    When the chips are mounted on the heatsinks its also important to use heatsink compound between the chips body and heatsink
    (TV's are dangerous and should only be examined by qualified personnel all information supplied for information purposes only anything carried out at owner of product own risk)
    Let me know,if needed further assistance.
    Hope i helped you.
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Sony wega model KLV-L32M1
Likely intermittent power supply failure
Feb 09, 2014 | Sony Televison & Video
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2017 | Sharp LC-32SB23U 32 in. LCD TV
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
I stored my TV for 2 years and when I went to turn it on the green power light came on for 10 seconds then turned back off. That's all the TV does now. The screen is blank and the TV does not come on.
Try this:
1- Unplug power for 10 minutes.
2- Plug in and turn on again.
if it doesn't turn on then The power supply is bad. Usually the power supply unit can be replaced, but you have to open the case to see how it looks like before order the same one.
Jul 03, 2009 | Mitsubishi HD1000U DLP Projector
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Mitsubishi WS-65711 65" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
