Question about Roper REX4634KQ Electric Dryer
Needs a new belt? Dryer not turning Roper, model unknown
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryerneeds a new belt? Dryer not turning - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 06, 2010
I have a roper dryer model red4440vq1 and it want start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 29, 2011 | Roper Dryers
Dryer works and come on but won't turn to dry. its a roper by whirlpool
Check your belt.
This video on replacement should help you in opening the top panel so that you have a good view of the drum and belt (turn off the breaker and unplug your dryer before proceeding with any work).
http://www.youtube.com/watch?v=GZsDbMuimm8&feature=channel
Replacement procedure is the same as shown in the video. If the belt is broken check the tension pulley on the bottom before purchasing or ordering a new belt, some Roper model came with a "tension slide" and not a tension wheel (mine was one of them).
http://www.applianceaid.com/WLP_idler_slide.html
The slide will wear and a groove will form that will accelerate the wear on the belt, this part can be replaced with a normal tension wheel (recommended), so you're not repeating this repair in another few months or so.
Apr 23, 2011 | Roper Dryers
I have a 9 year old Roper dryer. Went in today to turn it on and the motor sounds like its running, but there doesn't seem to be anything turning and I hear a high pitched squeaking sound. Any thoughts??
The problem is likely the dryer belt . Here is a video Dryer belt replacement video . It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Feb 21, 2011 | Roper REX4634KQ Electric Dryer
Roper dryer will not run. Model # REX5634jq0
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 30, 2011 | Roper REX4634KQ Electric Dryer
I have a Roper dryer Model: RED444OVQ1 that won't turn on .
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 20, 2011 | Roper Dryers
Roper dryer model REL4434AWO has stopped spinning. Heating element works. Belt seems secure around drum.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 18, 2010 | Roper Dryers
Dry run no heat
Dryer Repair - The
Dryer Repair - The
heatman101
May 15, 2010 | Roper REX4634KQ Electric Dryer
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Oct 06, 2009 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
181 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
