Question about ATI RADEON X1300 Pro 256MB PCIE Graphic Card
Blank screen after powering up I get a screen with choices of safe mode, use last known good configuration, start normally etc. after a going through each choice nothing good worked, and all I get is a screen like the matix movie with vertical lines scrolling down. Then nothing, just a black blank screen. Before all this happened I was getting an error screen saying display mode not supported. Sorry, for the poor english. But can you suggest anything before I decide it is the video card.
  • 472 Answers
Check the fan on your video card if it has one. If it does have one and it's not working correctly then it will overheat very quickly.
This sort of issue can be caused by a million things but your description points to the card overheating or the memory on the video card dying.
Posted on Apr 10, 2008
My labtop came to a boot up screen that has the options: safe mode, safe mode with networking, safe mode with command prompt, last known good configuration, and start windows normally. i have windows xp....
Hello xderekhx716, to choose the [least] likely {Mode} in order not to "Lose any Data," you want to choose; "Start Windows in Safe Mode." If an incident 'occur' before this 'window' [Popped-Up], then you want to "Start the Computer in {Safe Mode}. This 'way if you have been "Infected by a 'Virus' or any of the Computers Configurations have been 'changed,' or "Windows Shut Down 'Unexpectedly' than Safe Mode is the 'choice,' because the; least amount" of Operating Systems, applications will be deployed at "Startup," ie. Drivers, Programs... This will 'protect' the System' from further 'damage', if there was any? You will have the opportunity to analyze the situation safely. Next, if the Computer is having 'problems' starting, or the "Operating System is not 'responding' or there is "no change, than a "message" will identify the 'still' remaining problem; "Starting Normally." Then you want to 'choose,' start Windows at the "Last Known Good Configuration" also known as "System Restore." Finally, if this was just a "simple "Shut-down?" Than, "Starting Windows Normally" is OK! Follow all the instructions "carefully" in any of the "Modes" you may need to [Choose]. I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 08, 2011 | ASUS Eee 4G Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Eepc 900HA : Screen froze, then whent black. Activity and power lights still on. Removed battery/ reinserted and turned on. Got black screen with message " We apologize ... Four choices for restart...
good day.
with that problem may be your unit cannot shut down properly so as early as possible you must done with a proper shut downing of your unit.
so if that message will appear select on the "Last Known Good Configuration" and press enter, if this message will appear again you need to format your windows.
thanks...
Sep 10, 2009 | ASUS Eee PC 900 Notebook
My computer won't boot.
This would be a good time to recover or roll back what you did, There must have been a change in your configeration.
Jun 09, 2009 | HP Pavilion dv4000 Notebook
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Having problem with IMB thinkpad R31.
windows xp logo comes on-but then it has a blank screen. wont go in safe mode,etc.i do not have the disk to reboot.
Oct 21, 2008 | IBM ThinkPad R31 2656 Notebook
Computer will not start
Choose Last Known Good Configuration. If that doesn't work, choose Safe Mode and then do a system restore to roll back your PC.
Any further questions, please use the comment box below to respond. Thanks.
Worldvet
Jun 16, 2008 | HP Computers & Internet
Emachine loop again
Try first of all 'Last good configuration'
If still no go consider what it is you have done latly in termso of installing new software or a new hardware device.
Remove the most recent.
Finally in Safe Mode go to Start/Programs/Accessories/System Tools/System Restore and reset the machine to a time before the problem started.
May 11, 2008 | eMachines T5274 Desktop PC
Laptop won't comeback on
Try safe mode.
On safe mode return the computer to an earlier date configuration.
At some point will ask if you want to do that. And say yes.
Make sure that if for some some reasons it asks you to restore the computer to factory settings, you should say no. I hope you can do this.
Mar 31, 2008 | Toshiba Satellite 1405-S151 Notebook
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
137 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
