Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
Pull chain broke off how do i get it back in. took it apart how do i get it back in
    Scholar:
  • 130 Answers
You can purchase a new switch at a local electrical distributor or go online to mcgill pull chain switches
Posted on Jun 06, 2010
Husqvarna 450 rancher chainsaw locked
Did you try and pull back the chain lock shield. its the handle abouve the bar, if you hit it it will lock the chain. Pull it back
Nov 20, 2012 | Husqvarna Garden
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
I have 2000 ls , took eng apart and found cam chain broke. and wonder what cause it to break clean? nothing is bang up.should i place cam chain and that be it or there more to it?
Very rare that a chain breaks. I'd replace the chain and before closing it up, turn the engine by hand and see if anything is binding or frozen in the valvetrain. Also look carefully at the valve springs to make sure that no valves have bent. (if bent, most times the spring will not return to normal height)
May 16, 2011 | 2000 Lincoln LS
Chain to the valve train on right side of the
Other than the chain breaking? I would recommend replacing all the chains while it is apart. Also all timing chain tensioners, tension arms & guides.
I don't have an answer to why, your specific parts,wore or broke.
May 04, 2010 | 2001 Lincoln LS
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Pull chain broken
Yes, You should be able to find a replacement switch with new pull chain at most hardware stores in the electrical section.
Good Luck!
- Jim
Feb 11, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
How to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
Jan 31, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
280 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
