Question about Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Starts but will not stay running
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 46 Answers
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Posted on Jun 06, 2010
4 Suggested Answers
  • 115 Answers
SOURCE: Mantis tiller won't run at high rpm
check the carburator, it sounds like a main jet is clogged or the carburator is dirty. Is the air filter clogged? Is the motor under strain?
Posted on Jul 04, 2009
boscia
  • 163 Answers
SOURCE: Mantis Tiller
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
SOURCE: trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
Posted on May 18, 2009
How to adjust a aisen carburetor for a mantis tiller/cultivator
Take it apart and blow and clean it out. Needle may be stuck.
Mar 08, 2016 | Mantis Garden
Mantis tiller 7222e
Hi anon, if it's starting your 2/3rds of the way there. You have fuel and spark. Try and clean the air filter first and if that fails to keep it running then check that the choke isn't staying out. If all thats ok then it may be the carb gaskets.
Jul 09, 2014 | Mantis 2-Cycle Tiller
I have a briggs an stratten engine on a tiller that will not stay running
It sounds like the air supply. Check the air filter.
Jul 02, 2014 | Mantis Tiller
Tiller won't stay cranked
the carb needs a thorough cleaning
May 04, 2010 | Mantis 2-Cycle Tiller
My mantis runs roughly for a short while then
carb may need work but change the air filter possible not letting thru air
Apr 21, 2010 | Mantis 2-Cycle Tiller
My mantis will not stay running unless the choke is full on
sounds like the fuel pump diaphram in the carb. you need to either be familar with it or take it to thae shop to replace
Jul 06, 2009 | Mantis 2-Cycle Tiller
Motor run but blades don't
mine is doing the same thing
May 14, 2009 | Mantis Tiller
Mantis Tiller
Nov 13, 2008 | Mantis Tiller
My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Oct 06, 2008 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
3,012 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
