Question about Dryers
Whirpool Duet hums but will not start.
Whirpool Duet has power and hums but will not start. Is this a problem with the drive motor or what? I found a quarter on the top of the blower housing that was shorting out a connection. I'm afraid the motor coils are now grounded. Any advice is appreciated.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryerWhirpool Duet hums but will not start. - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif RepaiWhirpool Duet hums but will not start. - 2_bing.gif rel='nofollow' href="http://www.fixya.com/support/t4747857-the_dryer_is_not_functioning_at_all_ther#">dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 06, 2010
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
My duet washer will not spin. it try's but doesn't get going
Please check if during the spin cycle there is voltage on the motor.
If so check the capacitor to the motor, if the motor hums there is fault in the capacitor or the drive being jammed.
Jan 15, 2013 | Washing Machines
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Whirpool Duet Washing machine F-11 error
I purchased a Whirpool duel washing machine Aug 05. In June of 08 it showed an F11 error. After factory repair service tech. looked at it he said that i needed a main motor at a cost of $400.00 After search on internet many people reported problems also and decided not to repair it. Has any one had problems with theirs?Ihave the same problem is there any solution????please help
Jan 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool duel washer agitates or washes but
have you replaced the motor control. i had this happen 1 year ago and had to have it replaced. i am having the same problem and have done some testing but have not found anything else. you can buy this part from whirpool for about $160 delivered to your home. this is exactly how it acted the 1st time it went out. some loads would spin out great and the next load would be wet.
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer pump hums, but won't start.
is posible that the motor is damage, also check if the pump propela is loos
Aug 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F11 alert in the Duet Whirpool Front Load Washer
F11-Serial communication error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.(you can find the location of CCU and MCU through the manual)
All the best,
sunny
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool waher
f/06 is a drive motor tach error.
Check wiring harness, drive motor,mcu.
and check that the drum turns freely
Oct 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
98 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
