Hose leading from drum leaking - Washing Machines
  • 35 Answers
Replace the outlet hose
Posted on Jun 06, 2010
Testimonial: "Thanks. There's an appliance parts store less than a quarter of a mile from me. Very helpful and prompt. Thanks again!!"
Washing machine leaking from the bottom. I called a technician he told me it was the pump. I checked and i notice that the leaking comes from a black hose.
See if you can adjust the clamps
Get yourself a light and clean everything around hose so you can see where the leak is coming from. Sometimes the pump will spray the water and looks as the hose.
Apr 01, 2015 | Washing Machines
The hose from drum is leaking how do i fix it
Take the front cover off. (usually two screws at the bottom) You'll see the hose attached to a tube welded to the drum. Check the hose for cracks and also check around the tube weld. If that's leaking you sometimes can fix it with J-B Weld, a 2 part epoxy for metal. If just the hose, buy one at an appliance parts dealer and install it with the original hose clamps.
Mar 07, 2015 | Maytag Washing Machines
Washer leaking water on floor
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Feb 11, 2011 | Frigidaire GLET1031WH Top Load Stacked...
Leaking
Hi
Water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Jan 01, 2011 | Washing Machines
Water leaking from bottom of washer between the washer and petestal
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps... Please post back if you need more information.
Daniel
Dec 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaks out the front of machine
Hi
Daniel
Sep 01, 2010 | Roper RAS8445KQ Top Load Washer
MY Whirlpool AA1400 5145 I had remove bottom drain and there is some blocking then I don't know whow comes first the ball or the rubber. Regards, OA
Hi
I hope I understood your question properly.
When you take off the drum drain pipe, you have a plastic ball and plastic ring inside the cup shaped hose which fits on the bottom of the drum.
When putting it back on, first put the plastic ring inside the cup-shaped hose. Then put the plastic ball on top of it.
Secure the hose to the bottom of the drum with the metal clamp. Make sure it is on correctly and will not pull off.
Also make sure there are no kinks in the hose leading to your drain filter.
Start a quick cycle and monitor the machine to make sure there are no leaks.
Best Regards
Ash
Nov 15, 2009 | Whirlpool AWM5145/2 Front Load Washer
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Leaking from the back
although my knowledge og the LG machine is limited i can tell you I remember there being an issue with the water backing up through little sensors(mushrooms they were called because of there shape), there are 2 of them on the top; of the drum area and can be pulled right out, they merely "float" up nad down and overtime become "stuck" form the soap suds building up around them , so if you lkoacet them and pull them out, simply clean them off and sorrounding hole in which they came, you should be fine, also very important that yo uuse HE deteregent.HE detergent is specifically formulated asnot to suds up causing these problems. hope this is helpful
Jan 22, 2009 | LG WM-2277HW Front Load Washer
Need to find the filter as drum not spinning and water leaking
The filter on this model is in the main hose leading from drum to pump. It can be accessed by removing the panel at back of machine.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
