Question about Refrigerators
There are 2 light bulbs inside the refrigerator. When I close the door they stay light. I can feel the heat when I open the door.
  • Refrigerators Master
  • 1,711 Answers
The door lights are controled by a limit switch which is located on the door. This switch can be also pressed with your hand while the door is open so you can check if the switch work or not, just keep it press and see if the light goes off.
You should also know that around the door frame internaly their is a heating element which keep the door frame shlightly warm in order to avoid the creation of ice and thus the door will stuck so check if this the heat you are feeling.
Good luck
Posted on Jun 06, 2010
  • jlouer Jun 06, 2010
    I tried pushing the button. The light stays on. Should it go off immediatly or is there a delay? It is a double door Kenmore fridge and it is definetly the light bulbs staying on that cause the heat. I tried all combos with both doors - lights stay on
  • espressonist
    espressonist Jun 06, 2010
    Their is no delay, light should go off at once. So you need to replace the door limit switch since from moisture and long time use the contact stuck and stay always on. This is a delicate jop and need to take care not to damage the fridge frame. Also you need to remove completly the electrical socket so their is not electricity while you are working on switch.
Frigidaire FFHS2612LS4 wont stop beeping
Hey Brandon, this is JK. Thank you for your post. I understand that your refrigerator is beeping none stop. When the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut off. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm will reset. The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping. Check to make certain that the gaskets on both doors have no gaps and that the appliance is maintaining the desired temperature. If all of these suggestions pan out and the problem still persist, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Hope this helps!
Mar 10, 2014 | Frigidaire FRS3R5EMB Side by Side...
Light stays on
Check the door frame for a protruding small lever that gets pushed down when the door closes. If one is visible, that should be the light switch, which probably went bad and needs to be replaced. Without a model # hard to say how the light are set to go off, but most use the above method, hope this helps.
Jan 30, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a Kenmore Elite stainless steel three door refrigeator I bought it oct 07 at sears. This am I got up opened the refrigerator door and it was hot inside I think maybe the door was ajar over nite can...
Do you recall if the door opened easier than normal that morning? its possible, but not likely, that the door was open, but its kind of hard to make those frech doors stay open even partially. you may have a bad light switch not shutting light off. is any of the plastic around the light bulb melted?
I have to think its something with the light bulb, since you say it was hot inside. thats a far cry from the not really cold i normally hear from my customers.
some french door fridges use a sort of finger mechanism located at the top outer corner of doors, if this breaks, the doors might not close easily by themselves, or worse, not stay open. without personal inspection, i cant give definitive answer
Mar 01, 2010 | Refrigerators
We have a Kenmore 20 frostless side by side refrig. It was in the home we recently purchased. When I open the refrig side the door makes a thumping sound at about 3/4 of the way to fully open. It feels...
there is a door cam on the bottom of the door,you have to take the door off to repair it,it's pretty easy to do,if you send model number i could have looked it up for you and gave part number,model number will be inside fridge side up near ceiling or down near the bottom hindge,you will need this to order your part,good luck with door,if the light is staying on take bulb out so the fridge doesn't heat up
Nov 21, 2009 | Kenmore Refrigerators
Refrigerator light stays on even when door is closed.
Turn off the Low Ambient Switch on the upper panel of the Refrigerator door. That will turn it off.
May 06, 2009 | Dometic NDR 1292 Refrigerator
GE Refrigerator
If you have heating in the freshfood side there is only one possible. The light inside is staying on and allowing the bulb to heat up the refrigerator. To fix this you will need to replaced the door switch. To check simply unscrew the light bulbs and see if the problem goes away, or open the door and push on the door switch and see if the light is going off. Please let me know if this is not the problem and I will be happy to help. Please let me know if this did FixYa.
Mike
Sep 07, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
