Question about Samsung Refrigerators
Model sr 52 nx refrigerator and freezer no cooling.refrigerator light is on.
  • upatwari Jun 06, 2010
    IS THERE A CHILDLOCK IN SAMSUNG REFRIGERATOR SR52NXA
  • 1,284 Answers
Hi, all the things in your refrigerator are getting warm. The freezer is thawing and when you listen closely you hear a click with a buzz, another little click and then nothing for a few minutes. Then the same thing starts all over again. You fear the worst and you are probably correct. The compressor has decided that it will not start anymore.
When this happens, sometimes it is the fault of the capacitor or the start relay. There is about as good a chance that changing these components will work as it is that it will not work. If you can do the changing your self then you should get the parts and do the work. You have half a chance that it will work. If you will need to pay someone else to do the work then you need to look hard at what it will cost you and what the unit is worth, then decide to take a chance or not.
If you do decide to change the start components then you need to make sure that you unplug the refrigerator long enough the let the compressor cool completely. Even with new components a hot compressor often will not start. Believe me if your compressor is trying to start and can’t then it will be very hot!
If you end up needing to change the compressor, get a complete price so that you can make a good evaluation of the cost versus replacement. Make sure that the replacement will not cost more than half the replacement costs. Why pour money into something that will have something else fail before too long? Also remember that federal laws require a certification to handle refrigerants and persons doing the job need to recover or reclaim all refrigerants and handle them accordingly. A compressor replacement is NOT a DIY job. Specialized equipment is needed to do the job properly.
Take care
Posted on Jun 06, 2010
  • 713 Answers
Hi,here is a detailed solution to help you solve the problem with your unit;
Fix #1
First of all, the most simplest thing to do is to check the temperature. It might very well have happened that the temperature control may have been turned off unknowingly, which is the reason for the problem. So if that's the issue, just set the refrigerator at 37 degrees and you are all set.
Fix #2
Poor coiling leads to a heavy frost build up on the evaporator coils. A frost build up, specially on the ceiling of the freezer, is a sign of problem in the self defrosting system or damaged gaskets of the doors. Therefore, check if the refrigerator is facing such a problem and defrost the refrigerator. It would not cool well if the defrosting is not happening properly.
Fix #3
A dirty condenser may be the culprit for your refrigerator not cooling well. What will happen in case if the condenser is dirty is that it will cut off the extra load. That work is done by the thermostat on the side of the compressor in case the refrigerator heats more than usual. To rectify this problem clean the condenser coils using the vacuum cleaner. These are either behind or beneath the refrigerator. Read more on how does a refrigerator work.
Fix #4
In case the refrigerator is not leveled, that too can lead to the refrigerator not cooling properly, because if the level is not right, the door of the refrigerator may not close correctly, causing cooling problems. If this is the case, it might be necessary to ensure that refrigerator is at level and is slightly tilted back. Do some adjustment to get that correct level using a wooden block or see if the screws on the leveling legs need some looking into.
Fix #5
Check out the door seal. If the door seal is worn out, it will definitely result in frost build up and that won't allow the door to close properly, thus the problem of refrigerator not cooling. In addition to that there can be a problem in the door even if the level and other things are fine. You would need something to do about the door then. May be loosen the hinges and fix them in order to get the correct position of the door. Eventually tighten the hinges. Read more on refrigerator repair tips.
Fix #6
The food and freezer sections will go dysfunctional if the evaporator fan is not working properly. This is because then there will be no airflow to the freezer or the other sections of the refrigerator. Confirm if both the fans are working well by listening to the sound emitted by them. There is a possibility that one may work and the other wont. For that, may be you would have to look for a blockage or something in the one which is not working. Even after doing this you do not find any problem in the fan, you may need to replace it
Thanks and take care
My samsung refigrator Model SR-57NXA not cooling properly
HI TAHIR.try defrosting all for 24/48 hours first.good luck.Ali
Jun 25, 2012 | Refrigerators
The freezer is fine, but the refrigerator is too warm (set at 37...now at 52). The temperature control has power (it lights up)
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works refridgerator only cools to 52 degrees
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
I have Magic Chef refrigerator model MCBR415S frezzer is working but the refrigerator only cools to 52 degress what can be the problem
heatman101
Sanyo SR-4800W freezer is ok and cold stoeage is warm. Need to fix the problem.
heatman101
Mar 17, 2011 | Sanyo SR-4800 Top Freezer Refrigerator
Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Feb 15, 2010 | Maytag Admiral Top-Freezer Refrigerator
Refrigerators Logo
204 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
