Question about Keurig B70 Coffee Maker
Broken O-ring floating in water reservoir. Where does it go? Should I replace it? No leaks anywhere. Machine works fine otherwise
The o-ring you found floating goes around the black circle of plastic that surrounds the water inlet valve at the bottom of the inside of the reservoir. It's only used to create a seal when you're using the attachable water filter. If you're not using the attachable water filter, you don't need to replace the o-ring.
Posted on Feb 25, 2014
    Champion:
  • 213 Answers
As long as it's not leaking you should be fine. however if you have problems and need a replacement seal just go here,
http://iwantsweetdeals.com/ for your keurig part needs!
Posted on Jun 14, 2010
My oil reservoir is full of gas. Any idea what happened and how to repair?
What oil reservoir. Is it 2 or 4 stroke. If your fuel system has a float bowl with needle and seat that needle may have stuck or otherwise leaked fuel into the engine, past the rings and into the crankcase. Otherwsie you need to post more information about what engine etc etc you have.
Nov 08, 2014 | Garden
Low water indicator flashing
The magnet inside the float loses its magnetism with age.
Buy a replacement on eBay for a few bucks.
You cannot repair it, but the machine will continue to work fine without it - you just won't get a signal when your water is about to run out.
Jan 09, 2014 | Sunbeam Cafe EM6910
My Espresso Machine leaks out the bottom
thier is a puddle of water that leaks out of the bottom of machine after i brew my expresso
Dec 29, 2012 | Mr. Coffee ECMP40 Espresso Machine
I am still awaiting for your reply, athina_papamichael@hotmail.co.uk, regarding water reservoir cap steam leaking is this normal or do I require a new cap or rubber ring, otherwise I will have to take my...
Hello, no this is not normal. You just need a new O-ring. This is about a 1 dollar fix. The original O ring is clear rubber but a 3/4" standard O ring will work just fine. You can get these at Lowes or Home Depot.
Mar 26, 2010 | Tristar SB Steam Buggy Vacuum
Saeco Vienna Coffee Machine water leak
I have had the same problem with my Saeco Digital & Saeco Superautomica machines. After much work and somewhat expense I have finally found a simple fix. All you need to do is replace the gasket which is located just under the water reservoir.
(1) Take the water reservoir off
(2) Pop the round plastic piece located in the middle off (don't worry you won't break it as is it pretty tough)
(3) Take the black rubber gasket out and either:
(a) cover the present gasket with the brew group lube or
(b) replace the gasket with a new one.
which will give it a air tight fit and prevent any further water leakage from the reservoir.
You can get a new gasket for $5!!! :) I got mine at: http://cerinicoffee.com/item.asp?cID=0&PID=90
I also put some Brew Group lube ( http://cerinicoffee.com/Lube_brew_group_saeco.asp ) around the gasket as a temp fix until I completely replaced to gasket. Apparently, what happens is that the original gasket gets old, dry rots or whatever allowing the water to leak out of the reservoir. And then all over your work surface. The Saeco machines are quite intricate but are
Hope this helps.
-Dave
Nov 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Leak from salt reservoir on the DT999
Replace water softner seals (Hoover spares reference: 91941698) as stated previously. Harraps were doing them for £6 each. The softner is accessed by removing the R/H panel and unscrewing the air break ring nut from inside the machine. They are not a standard size so oem o rings are recommended.
Oct 15, 2008 | Hoover 24 in. DT999 Free-Standing...
Leaking
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Feb 25, 2008 | Solis Master 5000 Espresso Machine
Senseo 7818
My husband found in ours that the little float was stuck over the sensor (the little patch) down in the reservoir. The float could not rise with the water, thus, the machine did not know that there was enough water available and it would not stop blinking. He took the dry reservoir out, turned it upside down and shook it! This worked for him, as it unstuck the float. He said that if that doesn't work, the thing is really stuck and you might as well return it.
Jan 13, 2008 | Philips Senseo HD-7810 Coffee Maker
Keurig B70 Coffee Maker Logo
2,526 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
