Question about Smeg WM16AAA Front Load Washer
Smeg WM16 AAA will not start without banging door likewise once engaged to open the door you have to bang it really hard to get the latch to disengage. Anyone know what causes this and how you fix it?
  • 35 Answers
May be door switch is prob check the door switch
Posted on Jun 06, 2010
I have a 2002 Acura MDX and the latch is jammed or broken and the door will not click shut because the latch will not catch. Is there a way to fix it without replacing the mechanism?
Which door? Will the door close and not latch or will the door not quite close and bangs as you try to close it. Have a look inside the latch to see if the latch is in the locked position. If it is, pull on the door handel and use your finger to release the latch into the open position. If latch is in the open position, check the striker attached to the door jamb to make sure the screws have not come loose and allowing the striker to move causing the door to not properly close
Aug 22, 2015 | Acura Cars & Trucks
Cannot open door
The door interlock may not have engaged properly! This has happened to me and I use my knee and bang it against the door near the catch and once the lock is engaged the door open button will work. If not you'll need to remove the rectangular access panel above the plinth and get a flat head screwdriver in the slots to open the door.
Aug 30, 2013 | Miele W 2659 WPM Front Load Washer
First gear hard banging noise
You have a failed & worn out transmission
Seldom do they go 150,000 without a rebuild
Pull it out,no need to keep asking or worrrying
Its done,I once owned a trans shop if that helps
Aug 09, 2013 | Subaru Cars & Trucks
CDA wc370 dishwasher wont start,
Clean latch mecanisim ,,,,Close door fully , with a bang ,,
May 14, 2012 | CDA Dishwashers
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing powder door broken
The door is usually opened by a solenoid that is actuated by the timer. Sometimes, the solenoid becomes stuck in the open position. If so, you may be able to see the opening. You can try banging on the door near the latch with something relatively soft sometimes to free it but usually the door must be disassembled to repair it if it's an electrical failure.
Jan 21, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Dryer makes banging noise
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
Oct 02, 2006 | Maytag MDG9206 Dryer
Open Questions:
See all Smeg WM16AAA Front Load Washer Questions
Smeg WM16AAA Front Load Washer Logo
123 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
