Question about Clarion RAB250D
Clarion drx5675 wiring code the head-unit came with a owner's manual but nothing in the book about the wiring codes. please help
4 Suggested Answers
RAC_ICS
  • 143 Answers
SOURCE: I need a wiring diagram
to what car is it being fitted?
standard stereo wireing is as follows:
SPEAKERS
+White -White/black Front left
+Grey -Grey/black Front right
+Green -Green/black Rear left
+Purple -Purple/black Rear right
POWER
+12v Con Yellow
+12v Ign Red
+12v Antenna Blue
-12v Return Black
Tele mute brown
Illumination Orange
Hope this helps somewhat.
Posted on Dec 23, 2007
simplemitch
  • 752 Answers
SOURCE: Clarion RDB245D - owners manual
This is from the 225 but should be the same:
Setting the Clock
1) Press and hold the BND button 0, and then
press the DISP button 9 to display the clock
display.
2) Press and hold the BND button 0, and then
press the DISP button 9 for 2 seconds or
longer.
3) Press the SRCH Up button ´, then set the
current hour.
4) Press the SRCH Down button ´, then set
the current minute.
5) Press the BND button 0, then the clock is
set.
Notes:
If you select another operation mode while you are
setting the clock, the clock setting operation will be
canceled.
If you remove the vehicle’s battery for a check or
repair, the clock will be reset, so you must set it again
Posted on Aug 27, 2008
SOURCE: I'm looking for a wiring diagram for a Clarion drx5675
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Posted on Feb 26, 2009
I need to find a manual for CD player
Clarion Pro Audio Cd7770 Cd 7770 Wiring Harness Manual ...
www.fixya.com/search/...clarion_pro_audio_cd7770_cd_7770.../manual
Clarion Pro Audio Cd7770 Cd 7770 Wiring Harness, manual related issues. Get free help, solutions & advice from top Clarion experts.
Oct 01, 2015 | Clarion Pro Audio Cd7770 Cd 7770 Wiring...
How to reset Suzuki Grand Vitara 2006 after I punch in wrong code more than 6 time after I took out a radio compartment to fix it . The car start and shut off when one s I gear to D or R
Try disconnecting battery. Then re-connect the battery and type in the correct code.
You could try the factory default code, which is 0000. There is some confusion whether Suzuki/Clarion produces these audio units with a preprogrammed lock code (0000) or not, but its worth a try. If a previous owner has set their own personalized code then there is absolutely NO way for you to work around it. The audio unit will have to be removed and returned to Clarion for reprograming. A Suzuki dealer can help you with this, but they can not unlock the radio, only Clarion has that ability.
May 15, 2015 | 2006 Suzuki Grand Vitara
I need to wire my clarion DB235 directly to my new vehicle, have the wiring diagram for that, just need a wiring diagram for the deck harness ( DB235 ) to be able to do it . Thanks
Hi, your head unit has the standard color code for aftermarket units, but you can download the manual here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/020/020DB335.PDF
If you need anything more, please let me know.
Aug 17, 2011 | Clarion Car Audio & Video
I replaced the battery in my car. Afterwards, i started the car and checked the head unit. The 'Clarion' symbol came and stayed on. I tried pressing every button but no go. HELP!
You have activated the anti-theft mechanism and it's deliberately awkward to defeat or it wouldn't be much use.
First, check all of the documentation which came with the head unit or with the car when you bought it; the security code is often written down or printed somewhere. Also check in the glove boxes as owners sometimes write the code inside them.
If this fails and the head unit was a factory fit item, then visit your car manufacturer's nearest main dealer with proof of vehicle ownership, proof of ID and the vehicle's VIN number ("chassis" number). The dealer can then look up the code; they may charge you for it but most supply them free if you're a regular customer for sales, parts or servicing.
If the unit is not a factory fit item then you can either contact Clarion or one of the many online code providers. Clarion want proof of purchase, independent suppliers just want your money. In either case, you'll need to remove the head unit in order to write down the serial number which will be necessary to look up the code number. Some will just take your money and fail to provide what you need, so exercise caution and only deal with proven trustworthy traders.
Good luck and I hope that you will kindly take a moment to rate my answer.
Sep 29, 2010 | GPS
I'm looking for a wiring diagram for a Clarion drx5675 does anyone know where i can find one? Or can someone give me the color coding to the wiring so i know where they go to, thx
SPEAKERS:
Green = Left Rear +
POWER/ACCESSORY:
Black = Ground
Brown = Phone Mute
RCA Cables:
Gray = Front Output
Black = Rear Output
Feb 21, 2009 | Clarion RAB250D
Need Wiring Diagram For a Clarion DB245
You can download the user manual here, which includes a simple schematic for the wiring color code:
http://safemanuals.com/user-guide-instructions-owner-manual/CLARION/DB245%20INSTALL-_E
Feb 06, 2009 | Clarion DB245 CD Player
I have an error code 6 for a Clarion DRX5675, any fixes?
According to the manual, error code 6 is when the stereo can't read the table of contents on the CD. This could be due to scratches along the inner tracks of the disc, an audio CD-R that was not closed or finished, or the disc is being inserted upside down. If the error code only appears for a single or few discs, chances are it's not an issue with the player, but the disc(s) themselves.
Dec 07, 2008 | Clarion Car Audio & Video
Peugeot 406 (1999) LX + Clarion PU2293A 6-Disc Changer Problem
Bloody snap! I also have a 406. The button on the head unit is supossed to turn on player.My original unit wore out.I got a second hand unit which is also not recognized by the head unit. At the moment I dont know why,but Im not a man to give up easily and will give you the solution when I have it. I know it was working originally and it looks like the secondhand unit is faulty. thomaashamioton@email.com
Oct 04, 2007 | Clarion DC625 6-Disc CD Changer
Clarion RAB250D Logo
246 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
