Question about GE DCVH515GF Gas Dryer
Gas dryer heat not going on. Vent is now
Gas dryer heat not going on. Vent is now clean/new is there a reset or something?
    President:
  • 512 Answers
In duct area there is a thermo switch. 1/4"x2" white in color. two wires are connected to it. This goes bad from overheating due to dirty duct work. This stops dryer from firing to ignite gas. Replace and you should be good. You can check all other thermo switches with a tester. Some are silver and round some are what I stated.
Posted on Jun 07, 2010
Dryer is not heating. gas is on. Was working until now fine
Posted on Sep 21, 2010
Dlg2522w gas dryer not heating, cleaned vent, reset, unplugged, still won't heat, motor replaced last year
I tired the reset on the over temp. Did not work. How do I check the igniter/ gas valve and thermostat?
Apr 26, 2012 | LG DLG5932W Gas Dryer
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
My bosch dryer is not heating. we've cleaned out the vent and reset the button on back. should we call a repair person?
heatman101
Aug 18, 2011 | Bosch Axxis WTA4400 Dryers
My gas dryer doesn't heat very well, if at all. Do I need to replace parts or are there ways do check and clean parts.
First i would clean the dryer vent. If the vent is clogged then the dryer cannot circulated the air inside the dryer. This will cause long dry times. If the dryer heats at first then doesnt heat anymore after about 10 min you probably need new coils
Jul 15, 2011 | Amana ALG443RAW Gas Dryer
My frigidaire LEQ1442ES dryer runs tumbles but would not heat. Cleaned out vent, reset the house fuse not won't turn on, lights flash only.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 29, 2010 | Frigidaire FEQ1442ES Electric Dryer
WHEN I TURN THE DRYER ON THE HEATING ELEMENT HEATS UP. THE GAS TURNS ON FOR 17 SECONDS THEN TURNS OFF.IN ONE MIN. THE ELEMENT HEATS UP AGAIN THE GAS TURNS ON FOR 7 SECONDS.
the most important think in a dryer is the vent that goes out side,if this is not clean the burner will keep going on and off,try this unplug the vent and then try it,if it works fine then you know its ,your vent clean vent,then put vent back on,all gas dryers have to be vented outside
Sep 12, 2010 | Dryers
Heat won't stay on, comes on for a minute and shuts off
you could have a blocked vent line,try removing the vent line from the back of the dryer,also clean out the duct that the lint filter slides into,also if the ignitor is glowing but no gas you could have bad gas coils,part number 279834 but check to see if you have something blocked up from lint,the dryer should be cleaned out and blow out the vent line with a leaf blower once a year
Jul 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
New dryer does not dry clothes, cleaned vent to no avail.
make sure the vent is cleared ,sometimes all of cust / think they clean out but instead make clogg even worse,,, repl/coils remove 2 screews 1/4 in from botom panel heating coils are black in color simple fix,,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Dec 22, 2008 | LG DLG5932W Gas Dryer
LG Gas Stacking Dryer
Check the vent and make sure it is not plugged with lint. Make sure the vent hose is clear. The light is telling you something blocking the airflow. You might not be able to see it easily.
Jun 18, 2007 | LG DLG2524 Gas Dryer
Open Questions:
GE DCVH515GF Gas Dryer Logo
235 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
