Question about Frigidaire Dryers
I have a Frigidare dryer model GLE02152ESO, SERIAL XD63502511. Dryer is beeping insesantly and flashing E68. Help!
    President:
  • 1,554 Answers
The code E68 indicates that a button is stuck. Check the buttons by pressing them one by one to find the stuck button.
Posted on Jun 06, 2010
  • 1 more comment
  • Andy Baker Jun 06, 2010
    I have tried pressing all the buttons as you suggested. The problem still persists, however it is only doing this on the automatic drying cycles, and not on the timed only cycles. Any other suggestions?
  • Jahn27
    Jahn27 Jun 06, 2010
    Enter the service diagnostic
    mode and perform the key test to determine which key is
    stuck.
    Once the key is determined, try to unstuck it; replace the
    electronic control board if the
    error code
    continues to appear after the button is unstuck.
    Press and hold simultaneously the Select and Cancel buttons for six
    seconds to reset the control then immediately after the buzzer sounds,
    turn the cycle selector knob 5 clicks counterclockwise to
    position the
    cycle indicator light second from the bottom.
    Press and hold the Options and Cancel button simultaneously for two
    seconds to enter the service diagnostic mode. The buzzer
    will sound
    three times and all of the LEDs will flash indicating the
    service
    diagnostic mode has been entered successfully.
    Rotate the cycle selector knob 4 clicks to the Heavy Duty
    cycle; the
    motor runs with the heater off. The buttons can now be tested. Press
    each button and all corresponding LEDs should flash;
    otherwise the
    button is stuck or a faulty. Unstuck the key and perform the key test
    again; replace the control board if the problem is not
    resolved.
    Access to the control board requires the removal of the top
    panel and
    the console. Disconnect power to the dryer prior to servicing to avoid
    the risk of electric shock.
    Remove the two screws attaching the top panel to the rear of the dryer
    then slide the panel rearward and lift it off the dryer.
    Remove the four screws, two on each side, securing the console
    to the front panel then flip the console forward. Disconnect the wires
    from the control board and lift the console
    off.
    Remove the screws mounting the control board to the
    console and
    lift the control off. Remove the control board's rear cover by
    releasing the two locking tabs the flip the cover off the control
    board. Try to unstuck the faulty key and reassemble the dryer in
    reverse of the disassembly steps
  • y_clark50
    y_clark50 Aug 22, 2012
    need to replace the electronic control board where to get the part?'
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Frigidare electric dryer about a year ad a half old. When start button is pushed all lights on right side flash and unit beeps. Dryer does not run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Electric Dryer
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Apr 06, 2011 | Dryers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
ERROR MESSAGE E 68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Apr 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
E68 readout on the panel
frigidaire dryers have problems with the computer boards,i've seen the affinity dryer start by itself,it will start to beep and then i can start up,but that error is telling you one of the buttons are stuck,if all the buttons check good you have a bad computer board.hope this helps you out.
Feb 13, 2018 | Frigidaire GLGQ2152ES Gas Dryer
Dryers Logo
2,266 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
