Question about Janome Harmony 2041
Bobbin thread is phooey and loopy
I have a Janome 2041 sewing machine. Recently the bobbin thread is looped instead of normal stitches ...I cannot figure it out because it was sudden. I have changed needles, thread, and have a manual but it is in Spanish and I do not read spanish. The english version that should have been with the machine was not in it. Anyway, I need help to figure out why myu machine is doing this and how to correct it/.
Thanks
Dj
  • 1 more comment
  • Chris Myers
    Chris Myers Jun 06, 2010
    Is it looping on the bottom of the fabric?
  • Chris Myers
    Is it looping on the bottom of the fabric? If so it it probably a top tension issue, try this this quick test. With the pressure foot up, you should be able to pull the thread easily right
    before the eye of the needle and when you put the foot down you
    should then feel a fair bit of tension on the top thread. If you do not get tension with the foot down, check this: -set the top tension dial to 5 -raise the pressure before threading the machine -"floss" the thread by holding the thread as it comes off the spool with your right hand and holding the thread right before the needle. Make sure to do that with the pressure foot up. What happens is sometimes the thread doesn't go into the tension discs all the way due to lint or something else. hope that helps, Chris
  • Betty Fisher
    Betty Fisher Nov 05, 2013
    still looping on the bottom any other solutions
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
With the pressure foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps,
Chris
Posted on Jun 06, 2010
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
Why stitches on top are great but bottom are loose and loopy?
Check your upper threading. Make sure it's between your tension discs. Remember loops on bottom, something is wrong with upper threading/tension. Loops on top something is wrong in the bobbin area (like the bobbin being in upside down or a loose bobbin tension spring)
start by rethreading the top thread with the presser foot UP.
Jun 11, 2014 | Singer Quantum 9910 Computerized Sewing...
Janome 5900 sewing backwards!
Most likely, the bobbin thread is not in the bobbin tension. Rethread the bobbin and try again.
Loops on top of the fabric almost always mean too little tension on the bobbin thread; loops on the underside almost always mean too little tension on the top thread. Just backwards of most people's first guess. See http://www.picturetrail.com/sfx/album/view/22521551
Jan 18, 2014 | Janome Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
The thread from the bobbin is all loopy in the stitches
Always thread the sewing machine with the presser foot up.
This allows the thread to properly enter the tension control.
If the thread is not in the tension control as it should be, when it connects with the bobbin thread it is not tight enough to form a proper stitch.
The bobbin gets the blame because it feeds from the bottom.
Mar 10, 2010 | Janome Sewing Machines
Small loops forming on bottom stitches under fabric
Thread the machine with the presser foot up. This opens the tension so the thread can properly enter and be feed to the needle according to the tension setting.
When you thread a sewing machine with the presser foot down, the thread does not enter the tension control as it should and the control has no control.
No control of the top thread and it cannot "knit" with the bobbin thread and you get loosey-goosey-loopy stitches that appear to be the fault of the bobbin.
Feb 28, 2010 | Singer Quantum 9940 Computerized Sewing...
Thread keeps breaking and i can't get the stitch setting to go from stretch stitches to normal stitching
Be sure to check that the machine is threaded properly into the needle. Also look at the instruction book to be sure you have the bobbin inserted corectly and that the thread is place properly (threaded correctly) in the bobbin area. Some machines have a diagram on the machine, but if you do not sew frequently; it's easy to mis-thread the bobbin. Did your bobbin thread wind properly onto the bobbin (not loose or loopy). That too, can be a problem. Best of luck. Susan
Aug 04, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Janome Harmony 2041 Logo
280 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
