Question about Logitech Z-640 Computer Speakers
How do I hook this up,I have a green,yellow and black wire coming from the center but only red,green and blue plug ins on the back of my computer??
  • 76 Answers
Need a Sound Card for 7.1 audio channels
Posted on Jun 06, 2010
I'm trying to hook up a Kenwood kdc x492 to a 96
Battery is yellow
Accessory is white/red
Ground is black
Illumination is red/black
Power antenna is yellow/white
LF speaker +blue/green - grey/black
RF speaker +red/green - brown/black
LR speaker +blue/yellow -grey/white
RR speaker+red/yellow -brown/white
Feb 11, 2013 | Car Audio & Video
Cant find out wat color wire to hook up dimmer and illumination wires. when u turn on head lights, the radio comes on
here is the wiring
Constant 12V+White/Green Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Red/Black Antenna Glass Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 03, 2011 | 1998 Honda Accord
I've hooked up all the speakers. NOTE: I didn't read the instructions, as they are lost and I recently moved. I'm sure everything is right, I've read on here about this problem. I have the pea-green,...
Typically:
Lime green (pea-green) is front speakers.
Orange is for center speakers and sub-woofer.
Black is for rear speakers.
Pink is for microphone in.
Blue is for line in (MIDI or similar).
Mar 10, 2011 | Logitech Z-5300 Computer Speakers
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Aftermarket radio does not work
The wires in the radio are more likely:
RED : Main Battery Power
YELLOW : From Ignition Switch
BLACK; Ground
BLUE: Output for Accesory (Antenna o Amp)
Car;
Blue/Red: Main Battery Power
Pink/Black : From Ignition Switch
Yellow/Gray: Illumitation(Don't use)
Green/Black: Same
I may be able to email you a copy of the diagram (just to be safe...)
Sep 13, 2009 | Car Audio & Video
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Logitech Z-640 Computer Speakers Logo
299 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
