Question about Maytag Washing Machines
Top Load (SAV4655EW) machine would continue to wash through rinse and spin cycle. There is electrical current
    President:
  • 1,554 Answers
It is a transmission issue if the washer continues to agitate during the rinse and spin cycle. This requires you to replace the transmission assembly (part number 27001039) and cost you about $250 plus labor. You don't have to accept or reject and rate this post to add information or post your comments and follow-up questions.
Posted on Jun 06, 2010
  • srobeck Jun 06, 2010
    The washer does not go into rinse or spin cycle. It just continues in wash mode. When it ends, it is still full of water. When dial is in spin position & you open and close lid, it will go into spin mode. It doesn't do this when dial is pointing to rinse.
  • Jahn27
    Jahn27 Jun 07, 2010
    Replace the timer (part number 27001113). Unplug the washer and remove the screws securing control hood assembly to control hood rear panel. then rotate hood assembly forward. Remove the bottom of the control hood from the clips located on the cabinet top.
    Remove the timer knob from the timer shaft by pulling the black plastic tab located
    on the back of timer outward to release knob, then remove timer knob
    skirt. Slide a soft cloth under the knob skirt, wrapping the entire skirt and
    pull gently away from the control panel.
    Remove screws securing timer to control hood mounting plate. Disconnect
    wire harness terminal plug from timer by lifting locking tab and pulling
    terminal plug away from timer. Lift the plastic tab marked 1 located
    above the securing screw and sliding the timer to the side releasing the
    tabs securing the timer to the control hood mounting plate. Reverse
    procedure to install the new timer.
What should i do? It continues to add time and cycles?
just press the botton of each cycle want u want,like add rinse press rinse botton and it will add rinse,press spin botton it will add spin,but for washing,cant coz already set the time,default program for wash and cannot change
Oct 31, 2013 | Samsung WA50F9A8DSP Platinum 5.0 cu. ft....
Spin cycle not spinning
Check the lid switch for continuity.
No continuity, replace the switch.
Mar 08, 2009 | Maytag PAV2300 Top Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washer still full of water
It sounds like the lid safty switch is out. It is activated when the lid is closed for safty reasons.
Apr 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
