Question about Microwave Ovens
My garbage disposer turns on but it won't spin. I think something is blocking it inside. How do I repair it?
  • gary madsen Jun 06, 2010
    The allen wrench worked. Thanks
    President:
  • 1,561 Answers
Turn the garbage disposal on and off quickly and check to see if it has power. If it hums, the power is on. Move on to step 3. If it doesn't hum, it may have overheated and tripped a circuit breaker. Move on to step 2.
Restore power to the machine. Most disposals have an overload switch that trips when the motor starts to overheat. To reset the switch, look for a small red button on the bottom of the housing, and if it's there, push it in. If your disposal doesn't have an overload switch or the machine still won't run after you reset the switch, reset the circuit breaker that serves the disposal.
Clear the jam from underneath. On many disposals, you can insert a 1/4-inch (6-mm) Allen (hex) wrench into the bottom of the housing and manually move the motor shaft and flywheel to dislodge the jam. If your disposal has an opening for an Allen (hex) wrench, insert the wrench and move it back and forth until the motor and flywheel turn freely.
Press the end of a short broomstick against one of the impellers, and jab in one direction and then the other until it breaks loose.
This should fix the problem.
Take care.
Posted on Jun 06, 2010
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Garbage disposal is not working. There doesn't seem to be anything in it and resetting and unplugging/replugging hasn't worked. Do I have to take it apart?
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Apr 25, 2011 | Microwave Ovens
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
I am looking for the installation guide for our old FB11 garbage disposal showing the sequence of installation steps
hello and welcome to fixya,
could you please provide the make of the garbage disposal? it will help me to narrow down my search alot of units seem to be fb11 garbage disposal I await your reply Thanks
Rick
Mar 23, 2011 | Microwave Ovens
I bought a used home and the garbage disposal does not turn on
REPLACED WILL BE SHEAPER THEN REPAIRING AN OLD ONE.
Feb 18, 2011 | Microwave Ovens
Is there a reset button on a emerson garbage disposal model e404?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
Jan 05, 2011 | Emerson Microwave Ovens
Garbage disposal is not clogged: I can freely turn it with my socket when placed on the center nut. However, when I flip the wall switch to turn it on I can hear the motor trying to "fire" up but...
Your motor is damaged and is not worth repairing on a garbage disposal. Recommend you get online and look for a good waste king disposal. They have the best warranties, incredible prices, lifetime corrosion warranty, have 1000 rpm's faster than the other brands so the food is liquified for the septic systems, and I have never seen one that was jammed in 36 yrs. of service! Good Luck, Appliance Specialists
Dec 03, 2010 | Microwave Ovens
All of a sudden, the water is coming back up on my garbage disposal instead of going down, it also swirl. I tried to see if the blades are moving and they are free, not stuck, also there is nothing that I...
The drain out of the disposal is plugged up...
Take the drain piping apart and clean it out and then you will be good again...
heatman101
Aug 29, 2010 | Microwave Ovens
Blades don't rotate when unit is turned on
does the unit make any noise?? if so its prob bad..replace!....if no noise check under unit, there is a small red reset button..push up firmly.. turn on...keep fingers out please!
Mar 15, 2009 | Microwave Ovens
Microwave made a weird noise while heating--sounded like a garbage disposal. Should we stop using it and call for repairs?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 23, 2009 | Bosch HMB402 Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
