I have a Digimate III with 40GB hard drive. Screen has suddenly stopped display. Unit will download and transfer to computer but no display. Is there any fix other than replacing the screen.
I purchased a new case and screen from Exeltek Solutions
Posted on Apr 10, 2008
Ms 7050 motherboard drivers download
The makers of the motherboard should have them.
Jun 16, 2013 | HP DX5150 Desktop Computer Off Lease...
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
Jan 17, 2013 | eMachines eMD620-5133 Notebook
for replacing the hard drive, you will either need to attempt a full backup of a drive (google "backup hard drive __state problem__") or start fresh. There are different types of hard drive connectors (IDE, SATA, SATA II, SATA III, etc.) you must make sure you purchase the correct drive when you do so.
if you have an IDE 2.5in laptop drive with 8gb capacity, you could go online and find another IDE 2.5in laptop drive with a 40gb capacity and when you plug it in it will be blank. you can transfer your files over, but it is unwise to transfer the windows installation (if possible) so you will need a windows install disk. these can be downloaded from many places around the internet, and will work with the retail windows activation sticker located on the bottom of your laptop, or the back or side of your desktop.
this is just an idea to point you in the right direction, if you use a search engine, you will most likely find an answer to your problem
Aug 27, 2011 | Dell Dimension 4600 PC Desktop
I transferred a 40gb hard drive onto this 250gb go flex drive and then transferred it back. Now when I try to tranfer anything else to this drive, it only allows 40gb of space to transfer. I reformatted...
my computer does not read or detect my hard drive no matter what i do, and when it does read from the drive it does not upload to the computer. so what shall i do?
Jan 25, 2011 | Seagate O 250Gb Usb20 Freeagent Go Silver...
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
You can buy another external housing and then just swap the hard drive itself over to the new housing. The housing only cost in the 30 buck range if not cheaper. If you need to get the data off, you can also buy an EIDE/SATA to USB adapter that will allow the connection between an unhoused hard drive and a computer. CompUSA sells them for around 20-25 bucks.
Jul 05, 2010 | Maxtor OneTouch III Mini Edition 120GB...
Software downloads are available from the Seagate support site. Here is a link to the download page for Maxtor OneTouch III family. It should provide the latest version of all software that came with the new unit.
Hope it helps!
Jan 04, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Transfering data from Maxtor to a new computer
It's a USB Hard drive, so you should plug the USB port into one computer, put your information on it, then plug the USB port into the other computer. Browse the Hard Drive for your data. It's like a larger flash drive.
Feb 10, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
