Question about Hotpoint Ultima WF860 Front Load Washer
I get a small water leak almost just drips under
I get a small water leak (almost just drips) under the front of the machine that forms a puddle. Any ideas of the problem and how i can fix it?
  • 35 Answers
When its come from the front of the doors it is gasket prob or else its coming from the tub then oulet is not properly fixed ..
Posted on Jun 06, 2010
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Hi i have a leak under my hotpoint wdl540 the pipes are all clean and dry and the washing machine still works where would the water be coming from?
Could possibly be a little knick in the door seal or from the corner of the dispenser (the drawer in known to leak and the best remedy is to adjust the front feet so the unit is tipping back slightly, this allows gravity to help the flow of water in the drawer ). The valves could be leaking on the inner side if the machine, Really depends on whether it is a flood type leak or just a small puddle/drip. Run the machine pulled out, whilst stood on some newspaper, this should help trace the area of origin. Keep an eye out when it drains that your plumbing isn't blocked and so the drained water comes out of the standpipe instead of flowing away. Keep me posted or repost if you need further advice. All the best.
Oct 18, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
A puddle of water forms under the machine and
Hi
If its dirty water your drain in back is plugged. There is a pocket below the injector nozzle that the pressure is relieved in when the brewing is done. This pocket can get clogged with residue after a while and then overflows under the drip tray. The drain is in back just above the back of the drip tray. If you pour water in the pocket it should come out the drain. If it doesn't, clean out the pocket, and that should take care of it. If it does,t, I need more information.
Oct 30, 2009 | Saeco Vienna De Luxe Espresso Machine
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Slight leak
It dpends. see if you can see any staining on front of cabinet under the door , if you can then yes it will mean new seal.
Another source of water could be water from the dispenser trickling down the front of the m/c.
Another possibility is that you have a leak from under the front of the washer. Put a piece of newspaper under the front of the washer, this should enable you to pinpoint the source of the leak.
Hope this helps
Please leave feed back
Dec 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Water leaking under refrig
there is a drip pan under the freg. check the drain hole at the buttom fo the freeze side. make sure it is open.
you can get to the drain pan via front grill. pull the front grill. and you will see the drain pan.
Nov 07, 2008 | Amana SXD524VW Side by Side Refrigerator
Leaking on the floor on "small load" setting only
I have been selling and been doing factory authorized service on GE for nearly 30 years. I have sold many of this model. It's hard to imaging that a machine would leak water on small loads but not larger loads. In a case such as this, a servicer must remember to test the machine exactly as the home owner is using it. I would take pull the machine away from the wall and adjacent cabinets and dryer if hoses permit, (so that I could rule out water coming from somewhere other that the washer) remove the front panel, and have the home owner run the exact cycle with the exact settings and the same clothes load and soap used when the machine leaked. I suspect that some water is splashing over the wash tub. If you use a gentle cycle or a larger load you get less splashing. Even having a few more cloths items in the machine would reduce splashing. You might not expect a solution, but you do deserve an explanation. Some times the solution is strange, for example: I had a customer who said the washer leaked a lot of water onto the floor the first time it was used in the day, but worked great the rest of the day. I came out early the next day and tested the machine, and it did exactly that. What happened was the builder added on this new laundry room and the drain pipe went through the floor before the plumber added the trap. The builder then insulated the area but put the insulation on the room side of the trap, allowing cold air to freeze and plug the drain. After warm water pumped into the drain and most of the water overflowed the top of the pipe onto the floor, the rest of the water melted the ice in the trap and the machine worked fine until the next day after the water had a chance to form a later of ice in the trap again. The fix was simply to move the insulation to the other side of the trap. (OK, here in Minnesota we run into weird things like that, but my point is to test the machine exactly as it is used to find where the problem lies) I'd like you to post a comment when you find your solution.
Nov 02, 2008 | GE WDSR2080D Top Load Washer
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
205 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
