Question about Bosch Nexxt 300 Series WFMC2201UC
What does E:27 mean
Door locked E:27 showing machine wont do anything
  • 1 more comment
  • tlacroi1 Jun 06, 2010
    E:27 keeps appearing door wont open washing machine wont do anything
    brand new bosch 300 series used three times shows E:27 door locked wont open and the machine wont do anything
    i guess so but not what i wanted to hear
  • 6,784 Answers
HI. This is a very common error code with this particular unit. The culprit will be the door switch. The main control module cannot recognize the switch, due to the damaged circuit at the door switch mechanism. These are plastic based components that tend to ware overtime, during frequent usage. The main control module will not allow for a normal washing cycle while the door switch is in this state.The necessary actions are to have the door switch circuit replaced, asap. Due to the complexity of this repair, i recommend to seek the professional services of a local qualified Bosch technician. Mechanical and electrical experience is recommended.
  • E-27 - Failed door switch circuit.(replace door switch circuit mechanism)
Posted on Jun 06, 2010
  • 3 more comments
  • Michael Masters
    Michael Masters Jun 06, 2010
    Wow, i just typed your issue. You will need to replace the door switch.......
    Not sure why you rejected a correct solution's.. Maybe some alternative reasons....
    Good day:)
  • Michael Masters
    You seem to be expert jumping. The culprit in this situation will be the door switch circuit. It has failed. Your unit will NOT work with a damaged door switch circuit.......
    my machine is brand new only used four times how can this be
    how can this be machine is brand new only used four times
  • Michael Masters
    I understand how unbelievable this may be, considering the fact that it is a new unit, but this is the actual case here. This unit should be covered by the manufactures warranty. I would contact the manufacture or local sales department store for a free repair. Due to the fact that it is new, there should not be any issues with the warranty. This is just a case of a defective door switch mechanism.
My siemens siwamat xlp 1340 shows a lock key and wont operate
that means that the door catch is not operating properly you may need to replace the door lock yourself or call the washing machine engineer for a quote eric
Jan 13, 2018 | Siemens Washing Machines
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Im getting a "LO" error
The LO error code means the LID OPEN
Here is what the techicians service manual say to check
LO Door failed to unlock Door lock monitor switch does not indicate to the machine control board that the solenoid in the door lock mechanism retracted and unlock the door. 1.Check for debris inside inside the door lock mechanism, which may be jamming the lock solenoid. 2.check wire connections in harness leading from machine control board to door lock mechanism.
3.Check the door lock monitor switch for welded contacts.
4.Replace responsible component.
Jul 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
Clear error code E27
E 27 means you have a bad door lock. try opening and closing the door.If that doesn't work, you need to replace the door lock.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 04, 2011 | Washing Machines
I can't open the door of my whirlpool AWM 5080. I attempted to open it too early and now it won't open at all.
attempting to open it early wont do anything to it, your problem will be your door lock is faulty and the coil inside that heats up to lock the door isnt contracting after cooling meaning your door stays locked, try unplugging it from the wall for 5 mins then plug it back in u may get lucky and it will open but its not likely this will work but sometimes does, other than that u need to find a new door lock
May 04, 2011 | Washing Machines
E:27 error code. Wet laundry is locked inside the washer. How can I get the door open manually? I've already unplugged the machine and waited and tried resetting everything.
E:27 message means that the door locking mechanism has malfunctioned and/or is overheating. Unplug the machine for 30 minutes and try again. If that doesn't solve the problem you need to call the service.
Mar 05, 2011 | Bosch WFVC5400UC Washer
Flashing E:27 and is locked
E27 means that the door lock solenoid has overheated so the door lock will need to be replaced
www.ApplianceRepairLesson.com
Mar 05, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch wfvc4400uc error code e:27
That the message means that the door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If this doesn't remedy the error code, you'll need to replace the door lock.
Nov 26, 2010 | Bosch Washing Machines
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Washer wont engage
The door may not have been fully closed. stop/clear cancel the cycle. ensure door is fully closed and attempt to resart cycle.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Feb 08, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch Nexxt 300 Series WFMC2201UC Logo
204 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
