Question about Samsung WF448AA Washer
No power to unit
I have checked plugs, breakers. Still no power.
  • 35 Answers
Power pcb may be prob or main pcb check the suppy inside the machine
Posted on Jun 06, 2010
110 power on one side of unit, no overhead light no power on other side, no ac!
U need 230 volts so you may have 2 breakers , one for each 115 volt line or one dual breaker which takes care of both lines at same time. Check your panel.
Sep 20, 2017 | Heating & Cooling
Whirpool cabrio does not run or fill
check the power supply to the unit. if no voltage is found on the unit . check the wall outlet.no power at the wall socket ?? check the breaker box for tripped breakers if breaker to the wall outlet is off but good ,leave as is . check for grounds at the unit . if no grounds are present , turn on breaker . if it breaks with the dryer still not plugged in , search for any appliances connected on that line and unplug all. plug in the dryer then start it .if breaker opens , something is wrong with the dryer. call a qualified technician . thanks .
Sep 07, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
They plug it 110volts to 220volts
if the unit is built for 110 bolts and it is plugged into 220 volts, either the unit or the outlet circuit breaker is the problem. Circuit breaker can be reset - not so much for the coffee maker.
Check the circuit breaker and then see if another appliance will work. If not, the circuit needs troubleshooting. If the circuit works, then have the coffee maker serviced.
Mar 06, 2015 | Keurig Platinum B70 Coffee Maker
Dryer trips breaker after only a few mins of operation
Check to power at outlet for 220 volts
Check the breaker for the correct amperage cut off.
If the unit had an obstruction in the air flow, it would not trip the breaker.
Try running the unit with just cool air and see if it trips the breaker.
Odds are, you have a defective breaker.
Also, if the home is newly built, check the panel for loose connections at the breaker.
Or you could try a different power outlet, like the hot water heater.
If the unit continues to trip breakers on other outlets, you may have a short in unit.
Apr 29, 2014 | LG DLE2140W Dryer
We had a power outage and now our Maytage Gemeni stove won't go back on. Can't test the outlet, of course, since it's that weird huge plug, but all the other electricity is fine. The oven is completely...
Hi!!
Check breaker box for a tripped Double Breaker, probably 30A, If breakers are OK, unplug unit from wall outlet and wait 15 min. to reset the control board, plug unit it back up and check Range. You can check for power at the outlet using a voltmeter set on the AC mode.
Keep me posted!!
Dec 04, 2010 | Maytag MER5550 Electric Kitchen Range
We had a power surge now when i plug my fridge in it blows my circuit breaker
The power surge might have damaged the wiring to the refrigerator. You can check this one with a megar. That is only if the circuit breaker blows off, ONLY when the unit is turned on. Else, the problem may be that current is flowing through the neutral. You can check it with a tester and if so, report it to the electricity board. Else, as a temporary measure, you can connect your unit, bypassing the circuit breaker. But in that case the circuit breaker will never blow off regarding any complaints to the unit and may result in a slight power wastage.
Jul 05, 2010 | KitchenAid Superba Architect KSCS25INSS...
Has power but nothing comes on Mod. ACE 184 X SO Whirlpool
TURN OFF THE BREAKER AND UNPLUG THE UNIT FROM THE OUTLET...WAIT 2 OR 3 MIN. AND TURN BREAKER BACK ON AND
PLUG THE UNIT BACK IN AND TURN THE POWER ON....IF THE
SAME RESULT AS BEFORE...REPEAT ALL STEPS EXCEPT PLUG THE UNIT IN A DIFFERENT OUTLET...IF THE PROBLEM PERSISTS , UNPLUG THE UNIT AND MAKE SURE THE POWER CORD IS SECURELY FASTENED INSIDE OF THE UNIT AND CHECK FOR ANY BURNT OR LOOSE WIRES OR FUSES OR GROUNDS.
Apr 03, 2010 | Heating & Cooling
Midea model MSB24CR After a while cuts off flashing lights on panel (auto-timer- operation) . Cant restart until reset breaker Thanks
TAKE THE UNIT OFF OF AUTO-TIMER AND TURN THE POWER OFF
AT THE BREAKER...UNPLUG THE UNIT IF APPLICABLE AND WAIT
3 TO 5 MIN...TURN BREAKER BACK ON AND PLUG IN UNIT IF
APPLICABLE AND RE-PROGRAM. YOU MAY WANT TO WAIT TO SEE IF IT RE-PROGRAMS AUTOMATICALLY... AND RESETS...IF
THIS DOESN'T WORK YOU MAY NEED A NEW BREAKER...CHECK FOR ANY LOOSE CONNECTIONS WHILE POWER IS OFF...
Mar 27, 2010 | Heating & Cooling
A/c unit not working. Have thermistat set on 65 and temp. in house is around 85. check the breaker box for the house and it have not tripped
You must make sure that there is power to both the inside unit and outside unit. Is the room air blower blowing? If not you have either a plugged filter, iced up coil, the access door is not quite closed or there is no power to the unit. Is the outside unit fan turning? If not, you either have no call from the thermostat, the fan is broken or the unit has no power to it. I would turn off the breaker to the inside unit and switch the breaker near the outside unit to off and let them sit idle for 5 minutes. Switch both breakers back on and chect to see if the outside unit turns on. Then check the indoor unit and see if this starts blowing. Let us know what you find.
Jul 23, 2008 | Heating & Cooling
Samsung WF448AA Washer Logo
85 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
