Question about Boating
Engine turn over but will not start on 50 H P evinrude boat motor
    Champion:
  • 242 Answers
Check- Do You Have Spark At The Spark Plugs?If Not Then It Could Be Stator Or CDI Unit Or Trigger, If Yes Good!
Have Carburetor ('s)Got Fuel In Them? ,If Not Clean Carb's.
If Both Are Correct It Should At Least Fire
Good Luck
Posted on Mar 30, 2013
  • 46177 Answers
SOURCE: How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Posted on Apr 25, 2010
  • 75 Answers
SOURCE: I need a diagram for a carburetor for a 1990 Mercury Boat motor
this is just one of many carbs on a 50 hp merc
http://www.boats.net/parts/search/Merc2/Mercury/50%20(3%20CYL.)/9385911%20THRU%209469199/CARBURETOR%20ASSEMBLY/parts.html
if this isnt it just go to boats.net and check your modle number
good luck
Posted on Jul 06, 2009
  • 677 Answers
SOURCE: 1978-79 15 HP Evinrude boat motor hi low settings
High revs is 5500-5700. low revs is about 500. the low revs is in gear and idling.Hope this is the info you are after
Posted on Jul 27, 2009
  • 86 Answers
SOURCE: adjust the motor idle on a 1974 evinrude 50
Seat the idle mixture screw. Turn counter clockwise 1 1/2 turns. With engine running in gear under a load at idle slowly turn the screw clockwise until the engine bogs down and then turn back out 1/2 a turn. That is your correct mixture.
Posted on Oct 16, 2009
SOURCE: 20 hp evinrude boat motor will not start
broke key off of ignition trying to jump over, can't find wire to keep motor running, will start, but not stay running cause wired to toggle switch. can u help, please thanks, wayne (20hp johnson/evinrude
Posted on Nov 08, 2009
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
Evinrude Outboard Motor Model Numbers
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Doesn't seem to use oil? Oil reservoir never seems to go down?
The fuel to oil ratio should be 50:1, which means for every 50 gallons of fuel you use, you should use 1 gallon of oil.
You should see some smoke haze at starting and during running.
Having run an Evinrude that had had the auto pump disconnected in favour of pre-mixing fuel, I would take the boat to a marine engineer to check the pump and delivery. You know it is pretty disastrous when all the oil is burned out.
Sep 10, 2015 | Evinrude / Johnson 135-150-175-200 HP...
Why does our Evinrude 50 hp engine beep when we take the pontoon out?
possiby a dealer could tell you with a phone call.
Jul 07, 2014 | Boating
Will a 1973 50 hp Evinrude OMC lower unit fit on a 1988 evinrude 50 hp
Tony, that's a problem for the boat motor repair section.
Nov 02, 2013 | Vacuums
Adjust the motor idle on a 1974 evinrude 50
Sep 29, 2009 | Boating
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
Boating Logo
150 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
