Question about Smeg SE280X Stainless Steel Electric Single Oven
Smeg electric oven timer controls
The timer control on my oven is locked on A - the only light showing on the display is A. I cant set the clock or timer, or even get the oven to start. Is there a way I can clear this so that I can use the oven.
I dont knowwhat model it is. It is a 60cm single oven. There are 6 timer controls:
1 = set minute minder
2 = set end cooking time
3 = set length of cooking time
4 = set decrease time
5 = set increase time
6 = set manual / automatic operation
  • 7 more comments
  • aroha1 Apr 10, 2008
    thank you, I already tried that before I posted my question to the list.
  • aroha1 Apr 12, 2008
    I have now tried all these tests, and it has not made any difference, the A just reappears. Do you have any further suggestions please.
    Regards
  • Anonymous Mar 28, 2014
    oven to work manually with out using timer
  • Anonymous Mar 30, 2014
    The oven timer was played with and now we can not get the oven to operate. we need to reset the analogue timer
    Want to change time on aeg oven EE3003011 but "end" sign is still visible. How do I do this?
    Have tried to change the time of the clock on our Ariston oven. The minute minder is flashing, so are the numbers, they read zero but the end ones are increasing. I've tried what my book says for cancelling and for setting the time but it won't let me do anything. Please help as the oven won't switch on without the clock working
    tried to change clock time, the display is flashing with 50 mins and the A for automatic is flashing, have depressed the cook and ready buttons and tried using the plus and minus buttons but nothing is happening
  • Anonymous Mar 31, 2014
    the clock mechanism is damaged. it changes the time but it cannot be properly read because some of the bars on the numbers do not light up. the cooking timer fails. unable to set the timer for cooking
    the clock does not function correctly. it only lights up in parts so we cannot read the time. nor can we set the cooking time
    Genius:
  • 1,226 Answers
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • Emelio Navaja
    Emelio Navaja Apr 11, 2008
    Hello again,
    Please try to open the circuit of the timer, i guess it was grounded and need to be cleaned out to eliminate cause of time log. if not solve then, open also the circuit board or panel board of the oven and test it with tester to see fault it. please do series of testing .melnavz
  • Emelio Navaja
    Emelio Navaja Apr 14, 2008
    Maybe oven timer need to be replaced, please call/contact the vendor for the timer replacement of the oven. melnavz
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
Model SA392EB
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Feb 15, 2013 | Smeg Ovens
SMEG OVEN BRAND NEW WON'T HEAT
Sep 08, 2012 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 30, 2011 | Smeg Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
The light and fan works but no heat comes on in oven.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg SE280X Stainless Steel Electric Single Oven Logo
1,369 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
