Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
I have a brigs 6.75hp sometime it runs good and other times u cant get it started why
  • 36 Answers
Take carburator apart clean real well inlet line and all, it's not that hard to do!
Posted on Jun 07, 2010
How do I get a powermate 8hp brigs and Stratton generator to idle. I bought it and it wouldn't start. I cleaned the carb and it started on 1st pull, now it won't idle it run wide open all the time.
You have jet clogged, or still some obstruction in the carb. Hopefully you have a good inline filter .I'd take it back apart all the Jets and seats & Chem soak or a cheap complete rebuild.
Feb 09, 2016 | Coleman Powermate 4000 Watt Generator...
Troy bit self propelled mower just started running full blast constantly why
Throttle cable stuck ,or carby ,spray cable with WD40 and work the leaver back and forth,check carby to make sure a return spring hasn't come off,is the motor a Brigs and Stratton. Make sure the leaver at carby it moving whilst you are working the cable leaver,good luck.
Jul 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Murray 42" 20hp stops running
there are safety switches that can shut it off i would disconnect the coil wire from the harness its a small wire if it doen't shut off with that wire off its on the mower side causing the problem the other thing to check is to remove the upper engine cover and see if a mouse chewed threw the wires under there
Aug 05, 2012 | Garden
1993 jeep Grand Cherokee 4.0
I have had this happen with the Jeep 4.0 motors because the rubber hoses going to the metal intake from the valve covers had cracks or were broken. Its been a while sine I've been under the hood of a 4.0 but that is a good place to start.
Jan 09, 2012 | 1993 Jeep Grand Cherokee
Tcar runs good when running but stops and cant get started again runs days or weeks at a time with no problems. battery test good ,alternator is good just cant figure out. car has over a 125000 miles on it...
Check and make sure your temp sensor is working properly. Sometimes this will not allow the right information to get sent to your computer. You can test this with a multimeter if you don't want to risk spending money on a new sensor. You can usually see how to test this if you have a repair manual.
Nov 16, 2010 | 2001 Chrysler PT Cruiser
I have no rpm's mower only runs slow. plugs foul with black carbon after 30 minutes. This is a murray 6.5 hp brigs any solutions
CARB NEEDS TO BE REBUILT. FLOAT IS STUCK.. AND CHANGE OIL AFTER REPAIR OIL WILL HAVE GAS IN IT AND IT WILL JUNK THE MOTOR IN NO TIME ... VOTE !
May 20, 2010 | Briggs & Stratton Garden
1982 yamaha xj650 starting
Check the electrical switch in the clutch lever, most bikes have one as a safety, so you cant start it in gear, unless the clutch is in, could be a faulty switch, also do you have a switch on your side stand, sometimes these can be faulty as well.
Apr 17, 2010 | 1982 Yamaha XJ 650
4 hp brigs engine on merry tiller sitting around for 2 years and won't run, but will start with starter fluid.
change out the gas in the tank. make sure fuel line from tank to carb is clear. if this is all good then you might need to clean and rebuild your carb, if you are not getting fuel through the carb to the engine.
definately a fuel issue.
Feb 28, 2010 | Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
206 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
