Question about VinoTemp TC-180SS Wine Cooler
TEMPERATIURE FLASHES 50 AND EA
What do i do to resolve this
Hi, please help me, i m facing problem by not having a wide display of my ea cricket 2007 windows 8 "1366x768" display setting, any one knows then please help. . .
Check out the game's display settings. and match it with your monitor display settings. I believe problem will be resolved.
Sep 01, 2013 | EA Sports Cricket 07 for Windows
When i try to turn it on i get picture and sound for about 2 seconds and then it shuts off and the red light flashes,
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 07, 2011 | Sony KDS-R50XBR1 50" HDTV
Television keeps turning off then there are 5 flashes of the red LED light followed by 1 flash then this repeats itself continiously
5 Blinks on this set means loss of SOS 5V on the P-board AKA power supply board. Replacing it should resolve the problem.
Jan 05, 2011 | Panasonic TH-50PV30 50 in. Plasma...
My internet connection is great but, nhl 10 wont
NHL 10 servers are actually kinda well-known for going down pretty frequently. I wouldn't worry about there being anything wrong with your PS3 or your internet connection, it is most likely something that EA will resolve shortly. If not, though, I'd definitely contact EA and find out what the deal is.
Feb 01, 2010 | Sony PlayStation 2 (PS2) Console
Picture and sound are not working.
Replace your lamp, This will resolve your problem.
The clicking sound is the Ballast trying to start the lamp.
Sep 26, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tiger woods 09 internet problems
Problem with the EA servers being overloaded from time to time or the people your playing against are disconnecting towards the end of the game. Its nothing your doing wrong. EA really needs to upgrade there servers cause I run into the same problem
Feb 09, 2009 | EA - Electronic Arts Tiger Woods PGA Tour...
Madden 09 ea server problem
ok SET SYSTEM CLOCK back 3 years. i know it sounds stupid, but it resolved my issue. ( FYI, you must be signed out of xbox live to set system clock.)
Dec 18, 2008 | Microsoft Xbox 360 Console
Red light flashes
This is a well known and very common problem with all Philips plasma tvs 42 and 50 inch. The problem is they used under rated capacitors in the power supply. If you have electronics experience or a friend that is, remove the cover and look in the back for malformed or leaking capcitors. Replace them and see if that takes care of the problem. The caps only cost $2 or $3 each, so the cost to try this is pretty reasonable although you might have an added cost of buying beer for your electronics friend. If this does not fix your problem you are down to replacing boards that can be purchased around $300 ea.
I have found my set will come on "finally" after I get the back of the set warmed up and the bad caps finally charge up. Hope this is useful.
Oct 24, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
VinoTemp TC-180SS Wine Cooler Logo
47 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
