Question about Dynex Voice-Certified PC Desktop Microphone
Plugged in but not installing.
I plugged it in to the mic outlet, but it's not showing up in my microphone option to install & it's saying none installed.
I have a Macbook Air with Microsoft Word Home and Student 2008 installed on it. I use the audio recording feature on in Word to take notes in lectures, but since the internal mic was not enough to capture...
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
Mar 22, 2011 | Apple MacBook Air
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
Installed USB microphone, but NO sound.
select the device from control panel /sound and audio device / audio .../sound recording ...
if it doesnt work ...look for the device ( microphone ) on volume panel ( double click the speaker from the system tray ) if you do not see a volume for mic...click options..and check the microphone from there ...after that look out and be sure it s not muted...it has to work if it is proper installed..
May 28, 2009 | Micro Electronics PowerSpec 8250 PC...
Microphone
dear mil20, this could be because of multiple reasons:
a) You've muted your mic from the speaker icon in task bar.
b) Maybe your sound driver is not installed correctly, can you play music in your system ?
c) You can check your microphone settings in control panel to ensure you've actually enabled microphone options. Also see if you've set default voice instrument speakers or headphone. Finally see if you've plugged the mic right.
d) If none of that helps you might like to take your mic and system to nearest hardware store to ensure nothings wrong with your hardware.
If that was helpful please press 'fixya'
Oct 22, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Can not find cd to install mic
Microphones do not require software or drivers to operate. First, double click on the volume icon located in the system tray. If you do not see the volume control for Mic, then you will need to make it show up by going to Options --> Properties --> Check the box labeled Microphone --> Click Ok. You should now be able to see the volume control for the Mic. Make sure that this is not muted and the sound is turned up. Second, you must have a sound card installed in your computer that supports microphones. Please check with your cards manufacturer or PC manufacturer to make sure.
Sep 11, 2007 | GE HO97880 Consumer Microphone
Dynex Voice-Certified PC Desktop Microphone Logo
232 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electric Dime
Electric Dime
Michel Laprise Sr
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
