Dog leash is stuck in agitator of washing machine...GE model WCSR417OG2WW...how can we fix this?
  • 35 Answers
Remove the agitator
Posted on Jun 06, 2010
The agitation does not work like it should!
I suspect u have bad agitator dogs
check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
25712554-jkb5ybrklduaa4afh4xyzipe-4-9.jpg however if u have a G.E U HAVE A AGITATOR COUPLER INSTEAD OF CAM DOGS SEE FOLLOWING PICS
May 25, 2015 | Washing Machines
Slow agitator
Sometimes it is a very simple fix.
Agitator dogs.
4 little plastic thingies that wear out so the agitator has nothing to grip.
I'm not sure if they are specific to each model washer but it's about a $5.00 try.
You have to take the agitator out.
I watched YouTube.
Pretty easy and far less expensive than a pro!!
It took 10 mins. The hardest part was getting the agitator apart, which takes elbow grease!!
Apr 19, 2014 | GE WVSR1060GWW 3.2 Cu. Ft. Super Capacity...
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Apr 06, 2011 | GE WBSR3140DW Top Load Washer
    I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
    You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
    Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
    Agitator doesn't engage in roper AX5133 washing machine
    Check these excellent youtube videos out I found while a surfin this here world wide web.
    Old school washers:
    Newer models:
    May 29, 2010 | GE WWSR3090TWW
    Agitator does not turn in my GE washer, it is 3 years old
    Sounds like the agitator dogs have aged and broken apart. these are easy fixes at about 5.00- 10.00 and require the removal of the one bolt that holds the agitator down. After confirming this, take your washer model number and make to parts store and get replacement dogs. Hope this hepls..
    Oct 27, 2009 | GE Washing Machines
    GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
    Tell me more Is there voltage to motor? The transmission makes it agitate .
    May 28, 2009 | GE WBSR3140DW Top Load Washer
    The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
    Dec 03, 2008 | GE WBSR3140DW Top Load Washer
    Washing Machines Logo
    105 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
