Question about Fisher and Paykel DEGX2 Dryer
No power there is no power, plug is fine power outlet is fine
  • Fisher and P... Master
  • 43,501 Answers
There can be many reasons why your dryerno power - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 06, 2010
Circuit breaker is fine but still no power on one bedroom. PG&E said it might be a bad plug/outlet.
Turn off the circuit breaker and locate the plugs that are on that circuit. There is a good chance that the problem is between the closest working and faulty outlet. Starting with what appears to be the last working outlet on the circuit, check that all the wires are secure in all the fixtures and outlets.
If that does not fix the problem, a varmint may have chewed through a wire inside the wall. If you do not have experience with home wiring, you should get an electrician.
Feb 26, 2013 | Electrical Supplies
I have (7) 20W bulbs on a newly wired line running on a brand new 200W Malibu transformer, worked fine for 2 days and now it's tripping the reset button - Any suggestions ??
1) Copy following link for malibu power pack tips for longer transformer life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Two plug choices on each outlet, Plug power pack into other outlet on receptacle.
Inspect for damage on outdoor outlet.
Replace outdoor outlet, and do not use quick connects. Connect wire directly to screws on side of device.
Replace GFCI outlet.
Feb 01, 2013 | Malibu Intermatic Inc. ML121RT Low...
2000 Isuzu Rodeo aux power outlet on the front dash cooks anything that gets plugged into it
Sounds like a short in the socket. Often times dirt and junk get into the socket and can short out the connection.
Sep 09, 2012 | 2000 Isuzu Rodeo
No Power
loose wires connection or pc board
Aug 25, 2017 | LG WM-2277HW Front Load Washer
Hooked everything up per directions. I plugged it in to the closest electrical outlet and nothing happened. The lights did not light up, the connected wall control and sensors leds do not light up. It...
Dear Davehibshman,
Firstly; dismantle the plug and replace the fuse with the same rating as the one you have just taken out. Replace the plug cover, put the plug into the socket and try again. If this doesnt work, there may be a problem with the internal fuse (if one is fitted). Two choices here, either refer this unit to a qualified service personnel/ the place where you got it from, or do the job yourself (which will save you a whole bunch of cash). In your circumstances, I would take it back to the place you got it and ask them to put the fault right, or replace the unit completely; if it is past its warranty or guarantee time, then get back to me with a make and model number of the unit, and I will give you step-by-step instructions on how to solve this.
Yours sincerely
Oz
Feb 27, 2011 | Vacuums
Was working fine but acts like it has no power. No lights on, fuse breaker is fine, plug is fine
when you say the plug is 'fine' does that mean you've checked the line for 120 or 208 volts with a voltmeter? if so then the only thing to do is pull it apart and find out where your problem is. It has to be somewhere before any lights or motors. I'm assuming this dishwasher is on a GFCI breaker (the test/reset outlets that trip when wet), if so that would be to check if you haven't confirmed voltage on the outlet. Keep in mind it doesn't have to be on the outlet you're plugging the dishwasher into, it may be a few feet away, I suggest you just make sure all the outlets are working properly
Mar 06, 2010 | Dishwashers
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No light, sound nor green button
maybe a lizard is die inside and shock your power supply circuit
Jul 01, 2009 | RCA 36F530T 36" TV
Fisher and Paykel DEGX2 Dryer Logo
130 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
