Question about Bulova Watch
Bought a watch in vietnam - can you point me to the instructions? It's a xj-673H. Not sure of make! It says MOTILE on the back
Bought a Seiko 6N42 for my husband.We cannot get it to start.We've shaken it and the hands will not move.We were given a manual for a 5 so we're not sure these instructions work for his 6.Can U help
Take it to a jeweller, it sounds like it needs a new battery. $6 to $8 whilst you wait.
No point shaking it as it OUGHT to be electric quartz movement.
Dec 29, 2016 | Seiko Watches
Mossimo watch instructions
If it isn't working, return it.
Nov 01, 2013 | Watches
I have a cat watch and i dont know how to get the back of so i can change the battery.
Thank you for contacting FixYa.
I am not familiar with Cat watches, but here are instructions for basic watch backs:
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Aug 24, 2010 | Caterpillar (UB141344020) Wrist Watch
    Hi my name is Ned i bought casio 434 i need some
    If you haven't got instructions on how to do this, you can get
    instructions from the Casio web site.
    Go to the casio web site "casio.com".
    Select "support" and the "manuals",
    watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Jun 15, 2010 | Watches
    Xinjia xj-686 watch can't turn alarm off
    I have the same problem with the xinjia-686. These instructions posted for another digital sports watch worked for me.
    noavatar_s.gif davidtolond
    Rank: Guru citizen.gif jewelry_watches_small.png Expert
    Rating: 85%, 400 votes
    I have the AW21312W, which has 4 buttons:
    1. Light (Top left)
    2. Mode (Bottom Left)
    3. Start/Stop (Top Right)
    4. Lap/Reset (Bottom right)
    To turn the set alarm off, push buttons 3 and 4 at the same time, the alarm icon should appear or disappear
    To turn off the hourly chime, press button 4. While holding it down, press button 2 and the days of the week disappear. The chime is now off. If you want the chime, press button 4 and hold while you press button 2. When all the days show, the chime is on.
    Feb 19, 2010 | Watches
    Puritan watch link removal
    its sound simple enough but you will need to use a bit of force to budge the pin.
    you will need
    blue tack
    punch
    pin hammer
    pliers.
    Roll up the blue tack push onto flat surface , push the barcelet side on into the blue tack wthe arrows pointing downward.
    insert the punch into the hole and tap with hammer.
    do this until you have removed enough links then push a pin back into the bracelet and tap home withthe hammer.
    Aug 25, 2017 | Lucien Piccard 26024 Wrist Watch
    I bought a cote d'azur watch and didn't comne withinstructions
    if you take this watch apart and look at the backside, the side buttons are not connected. and there are NO workings for the "neet" time, date and hr hands, so the ONLY setting the watch has is the time. pop the back off and see for yourself, you can also buy these watches on EBAY for 5.00
    good luck
    Mar 27, 2009 | Watches
    Bought pulsar- no instructions
    Go to the pulsar website to see if they have a PDF file with instructions or scour Google with the Y182 etc. information. That info is the movement model number the Seiko website may also have information. Knowing the movement information may link you to instructions. Call or go to Otto Frei website, call them and they may point you to the right direction. They probably sell that movement.
    Nov 16, 2008 | Watches
    How to set up ladies roxy digital watch
    I found users instructions on roxy website at:
    http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
    We were able to program our watch completely!!!
    If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
    http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
    Sep 18, 2008 | Bulova Watch
    Bulova Watch Logo
    109 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
