Question about Refrigerators
GE refrigirator problem
Why is water not coming out of water dispenser despite changing the filter GE refrigirator?
    Scholar:
  • 44 Answers
You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Posted on Jun 06, 2010
Fridge and freezer suddenly not working only 1.5 yrs old
I guess the culprit in this case is the compressor.. Do you hear a sound when you are near the refrigirator.. it will be like a fan rotating at a high speed...
Mar 07, 2008 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
After installing a new mwf filter no water comes out of the dispenser. It worked before changing the filter. With the filter bypass plug installed - still no water. I held the dispenser for more than 3...
the inlet valve has jammed shut & needs to be replaced it's just coincedence that it happened when you changed the filter unless the taps turned off it has to be a faulty inlet valve.
Feb 18, 2011 | GE 3 Ge Mwf Smartwater Water Filter Fits...
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
Water dispenser
My filter is located on the inside of the refrigerator in the top right corner. It twists off and is easy to replace.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
Change water filter and water won't dispense
Was water dispensing before filter was replaced? If it was then maybe filter needs to be purged to get air out of line. Only 3 other issues it could be. 1. water valve coil on back of fridge is bad. 2. Water reservoir is frozen up behind shelves in freezer section. 3. Your microswitch behind dispensor cover isnt activating water valve coil. Not much else could be the problem. Start with the valve
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
