Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
It will both spray and **** up from the rinse position but not any of the cleaning positions
  • 14 Answers
Try and run hot water in the solution tank to remove soap residue build up and always run hot water through after cleaning carpet and storing to prevent future problems. Steve
Posted on Jun 07, 2010
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell 2x Turbo 9300 shampooer. It won' spray from the carpet/floor position. I re-booted it and checked for blockage - nothing. I flushed the hand attachment and got it to spray some...
The heater is glogged trust me. It is the size of a dollar bill with seven screws. take it apart and clean the water path also take a small drill bit to the ports of the heater.
May 31, 2011 | Vacuums
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    No sign of water movement from cleaning heads
    My Bissell ProHeat is not dispensing water thru the floor cleaning position. I get water flow thru the tool application. Any ideas???
    Apr 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
    My bissell pro heat 2X will not work, no water or solution comes out, what can I do?
    I think the instructions should have the user rinse the solution passage with water. The soap probably clogged your spray nozzles. I had the same problem, I used a toothpick to poke to hole open again. The solution sprays only. I can't figure out why the water is not spraying out though.
    Jan 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Rainbow shampooer
    i am trying to clean my carpet with the wet vac and when i push the button no water is coming out of the tubes what might be the problem?
    Aug 24, 2008 | Rainbow E series Canister Wet/Dry Vacuum
    No water sprays out when you squeeze trigger
    Generally this is because you didnt clean out the machine & so detergent dries in the jets & blocks them. Take apart clean & hey presto. next time rinse thoroughly when you finish & if you lend it someone dont believe they have rinsed it properly.
    Jul 12, 2008 | Bissell Vacuums
    Bissell 9400 ProHeat Upright Upholstery Hose
    Set Ready Tools Dial to the Hose
    Setting. This will allow spray and
    suction from the hose.
    Set Custom Clean Dial for Heavy Traffic, Normal
    Clean, Light Clean
    , or Rinse, as desired
    Attach the cleaning tool to the end of the hose.
    Plug in and turn on the Power Switch and Heater
    (if desired).
    Clean by pressing the trigger to spray solution
    onto the area to be cleaned. Slowly move the tool
    back and forth over the soiled surface. Release
    the trigger to suction soiled water. Continue to
    clean in the area, working in small sections, until
    no more dirt can be removed. Rinse (optional)
    and suction as needed.
    May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
    Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
